필요한 것
The controller consists of a grey case with a black cable and a connector.
Plugged into the case is a saftey pin. Shown here with a spare saftey pin dangling on the left.
Since the case is glued shut, it needs to be pried open carefully (probably causing some degree of damage). To do so, pry it open at one point with a thin flat screw driver.
When the opening is wide enough, a chip card may be used, in order to keep the damage at a minimum.
Before removing the circuit board one has to unplug the ribbon cable for the buttons.
After pulling out the saftey pin remove the white piece of plastic.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
Curt Seeling님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
