주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Ikea TRÅDFRI Gateway 수리는 저희 서비스 설명서를 사용하십시오.
  1. Ikea TRÅDFRI Gateway Teardown, Ikea TRÅDFRI Gateway Teardown: 1 단계, 이미지 1/1
    • The Gateway I'm tearing down today came from the Ikea Gateway Kit, which includes the Gateway, two bulbs, a remote, a USB A to Micro-B cable, a Ethernet cable and a 5V @ 1A charger.
  2. Ikea TRÅDFRI Gateway Teardown: 2 단계, 이미지 1/2 Ikea TRÅDFRI Gateway Teardown: 2 단계, 이미지 2/2
    • The Gateway has 3 status LEDs:
    • Network
    • Internet
    • Power
    • The cables fit neatly inside the plastic case.
  3. Ikea TRÅDFRI Gateway Teardown: 3 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 3 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 3 단계, 이미지 3/3
    • The top part of the Gateway easily comes off after you twist it slightly counter-clockwise.
    • There are two helpful markers on the side of the Gateway, when the top marker matches the bottom left marker, the top is locked, when it matches the bottom right marker, the top is unlocked.
  4. Ikea TRÅDFRI Gateway Teardown: 4 단계, 이미지 1/2 Ikea TRÅDFRI Gateway Teardown: 4 단계, 이미지 2/2
    • Closer look at the base.
  5. Ikea TRÅDFRI Gateway Teardown: 5 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 5 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 5 단계, 이미지 3/3
    • We flip the base and we see a sticker with the Ethernet MAC address and QR code used during the setup.
    • But not screws!
    • Let's heat up the rubber ring slightly to soften the glue and remove the ring.
    • Voilà, plastic tabs.
  6. Ikea TRÅDFRI Gateway Teardown: 6 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 6 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 6 단계, 이미지 3/3
    • We pry the 3 tabs and we see...
    • A tiny PCB!
    • Wow, that is one tiny PCB.
    • The PCB is held in place by 3 Phillips head screws.
  7. Ikea TRÅDFRI Gateway Teardown: 7 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 7 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 7 단계, 이미지 3/3
    • A mysterious unpopulated footprint, can I hear "debug connector"?
    • ISSI IS25CQ032 32 Mbit Quad-SPI Flash
    • Murata Type1GC 2.4GHz & 5GHz Wi-FI Module
    • The module includes the Cypress BCM43907 Wireless System SoC
    • Broadcom BCM5241 Fast Ethernet Transceiver
    • Silicon Labs Mighty Gecko EFR32MG1P132GI Zigbee and Thread Multiprotocol SoC
    • Seems to be the same SoC as the one used in the Ikea bulbs.
    • 934 3959 1624 - With the recent announcement that the gateway will work with Apple's HomeKit, it's possible this is the MFi chip
  8. Ikea TRÅDFRI Gateway Teardown: 8 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 8 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 8 단계, 이미지 3/3
    • A closer look at the Wi-Fi/Ethernet/Zigbee parts.
  9. Ikea TRÅDFRI Gateway Teardown: 9 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 9 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 9 단계, 이미지 3/3
    • Another look at the other parts.
  10. Ikea TRÅDFRI Gateway Teardown: 10 단계, 이미지 1/3 Ikea TRÅDFRI Gateway Teardown: 10 단계, 이미지 2/3 Ikea TRÅDFRI Gateway Teardown: 10 단계, 이미지 3/3
    • This concludes the teardown.
    • As a bonus, I include a shot of the USB charger and the remote, which I won't be tearing down today.
arturo182
회원 가입일: 09/26/16
111 평판
안내서 1개 작성함
댓글 6개
Why is everithing so yellow? Was it put outside?
Federico Barutto - 답글
In reality everything is white, it's me not knowing anything about lighting a shot well ;)
arturo182 -
Is it the same plastic they make everything out of?
I had one of their iPhone wireless charging cases and it was the same look and texture as my rubbish bin. Discoloured just as quickly too.
Leon Kernan - 답글
Well done, arturo182!
Nils Belde - 답글
Question: the chip with the model type: 1GC (SS6917059) is handling wifi? (that chip has a unreable code on it on my ikea-gateway and a larger “'grey”' stain on it than on your photo. (by the way: my gateway is busted, i guess that chip can’t handle a lot of python-commands (i used python to switch the ikea-lights on/off on a daily bases)
Patrick Becks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 74
전체 시간: 23,590
