주요 콘텐츠로 건너뛰기
JBL Charge 2 Teardown
필요한 것
동영상 개요
  1. JBL Charge 2 Teardown, Protection Grids: 1 단계, 이미지 1/2 JBL Charge 2 Teardown, Protection Grids: 1 단계, 이미지 2/2
    • Use a plastic spatula or credit card to open the grids
    • You should not have to exert too much force on the grids. There is a little bit of glue on it.
  2. JBL Charge 2 Teardown, Screw!: 2 단계, 이미지 1/2 JBL Charge 2 Teardown, Screw!: 2 단계, 이미지 2/2
    • Remove the first 4 screws
    • Blow up the round of plastic then take care of the remaining 4 screws.
  3. JBL Charge 2 Teardown, We're in!: 3 단계, 이미지 1/2 JBL Charge 2 Teardown, We're in!: 3 단계, 이미지 2/2
    • Now you can access the motherboard.
    • To disconnect the battery: disconnect the microphone first, it will make things easier.
  4. JBL Charge 2 Teardown, Drums: 4 단계, 이미지 1/2 JBL Charge 2 Teardown, Drums: 4 단계, 이미지 2/2
    • Unscrew the two screws of the white cover
    • Get out of his notch, and here's the battery!
    Nice tutorial on how to dismantle the device, but what if I want to separate out the power bank part of this device and dump the rest due to worn out speakers. Is it possible to do that? If not, will it still work as a power bank if I simply the wires to the speakers and remove them. I’d rather remove the amplifier as well so that unnecessary power consumption is reduced.
    David Moody - 답글
결론
다른 10명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Alexandre Isaac
회원 가입일: 04/07/13
2,863 평판
안내서 8개 작성하였습니다
The Repair Academy The Repair Academy 회원
Business
1 회원
안내서 20개 작성하였습니다
댓글 13개
About to try this, will give feedback
Rick Purchase - 답글
This is the charge2 + not the charge2
The Daniel - 답글
there aren,t any screws in the cap
Norman Ingham - 답글
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - 답글
You are welcome !
Alexandre Isaac -
Hello, I have a problem
I lost the speaker screws
can you tell me what type of screws I have to buy?
thank you in advance
bilal mesrour - 답글
Ce tuto ne concerne PAS le charge 2, mais bien le charge 2+
Le principe d’ouverture est bien différent !
jf.dedecker - 답글
So easy steps to follow. Thank you so much. The guide is really helpful.
It came handy when my boss complained about a fault, so I tried figuring it out, then I googled steps to dismantle, and pop! The video showed up. Really helpful. Thanks
omo4rmzion - 답글
This tutorial really helped :)
JITHIN ROY - 답글
Bonjour à tous, je constate que sur ce tuto on a des personnes qui gèrent donc bcp d'amitié
et de remerciement à tous vous êtes tjrs en mode cool et ça fait vraiment merci et n'hésitez pas à me demander un service
je serai fier de vous rendre service et encore merci Thameur
Thameur TRABELSI - 답글
comme vous l'avez sans doute compris "bcp plaisir"
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 137
전체 시간: 50,390
