주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Synthesizers 수리는 저희 서비스 설명서를 사용하십시오.
  1. KORG Volca Sample Teardown, Remove the screws on the bottom: 1 단계, 이미지 1/2 KORG Volca Sample Teardown, Remove the screws on the bottom: 1 단계, 이미지 2/2
    • Remove seven Screws.
    • Then turn the Volca around. You can now remove the two PCBs. Take care with the loudspeaker cable and the battery cable. In my picture the black cable is already loose.
  2. KORG Volca Sample Teardown, The PCB with the knobs and the main logic: 2 단계, 이미지 1/1
    • This is the main processor. It is an Cypress FM4-Series MB9BF164L.
    • 25Q03213
    • The DAC. AKM4384FT.
    • MV3241 / 49AG3 / P220
  3. KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: 3 단계, 이미지 1/2 KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: 3 단계, 이미지 2/2
    • This is how working buttons should look like.
    • If this isn't the case, clean these parts with a Q-Tip dipped in isopropanol.
    • Clean these parts as well.
  4. KORG Volca Sample Teardown: 4 단계, 이미지 1/2 KORG Volca Sample Teardown: 4 단계, 이미지 2/2
    • Here is a complete overview of the PCB containing the Step Touch Buttons and the FUNC and WRITE buttons
Christian
회원 가입일: 03/09/14
1,510 평판
안내서 8개 작성하였습니다
댓글 27개
Hello, thanks for this post. I have an issue with my volca sample, only sound left is outputting. can you show me where the audio jack output circuit is ? Would be much appreciated. I think it’s a spike made by my soundcard while turnung it on that caused this issue.
Orphée Design - 답글
Sorry, I can’t help you here. You may try www.korgforums.com. There are some discussions about broken Volcas.
Christian -
Hi,
My Volca Sample LCD is dimmed (knob lights are not working too, however button lights works) after accidentally liquid spill. Everything else is fine. Can you give me some tip about dimmed LCD? Tnx
Flick Simpson - 답글
Hi, you can try open the Volca and rinse it thouroughly with distilled water. Remove the batteries before. Then dry it with a fan and keep it open and let it dry on air for 24 hours. The re-insert the batteries and hope for the best. What kind of liquid was it?
Christian -
Hello!! I have an issue with my VS. The Button 7 keeps triggering without no reason and is a pain in the ass. I opened the VS and cleaned all the pads ans circuits but doesn´t seem to do anything. :(
rodtop350z - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 77
전체 시간: 6,728
