소개
An easy step by step guide on how to disassemble the Blitz Pro 800W blender.
== Key areas include==:
Red circles - Areas to focus on (eg. located where the screws would be unscrewed from section or removed).
Green areas - Indicating areas where the dissembler would grip with their hand (eg. where the main component divides into different sections).
필요한 것
Unplug the device from the wall and turn the powerbase upside down.
CAUTION: Make sure the cord is not plugged into the outlet in order to prevent electrocution.
CAUTION: Make sure the cord is also wrapped up to eliminate the risk of tripping.
Place the blade firmly into a vice, allowing the grey circular turning mechanism to face upwards.
Turn clockwise with multi-grip pliers the grey circular turning mechanism, until it detaches from the white plastic base.
CAUTION: Make sure a strong grip is applied to the component in order to minimise injury.
Securely tighten white plastic base into a vice.
CAUTION: Do not tighten the white plastic base too tightly into the vice, as the part will be more prone to cracking and snapping.
Gently, but repeatedly (using a Flathead screwdriver and a rubber hammer), with minimum force, slowly tap the bearings around the circumference (located in the red circle) until they pop out.
댓글 한 개
I need a new silicone gasket. I am surprised how soon it broke in half. Am I supposed to wash it separately after each use or not? Can I buy a generic replacement as seen on Ali Express instead of $12 for one? What size would I need? Thanks
