소개
I'm going to take apart a Kocaso SF70.
It's a tiny bit mistreated on the outside, but it's about under the hood, right?
필요한 것
The bent corner on the front is an attempt to lift the digitizer..
The bottom panel on the back went missing, and we tried to skin the top one with vinyl.
Slip whatever pry tool you have in, then lift the device up from the cover.
Use a smaller thing to get into one of the side holes.
(second image) Then you will be invited by
Blu-Tackthermal stuff and the chips. I won't go into detail.
To remove the ribbon cables, tuck something slim under the lock and push up. (Already done in the picture)
You don't need to take out the camera sensor's cable.
There's tape holding down the motherboard, in case you didn't notice.
(second image) The battery has little adhesive, so lift it too and it's all off.
Pull the speaker and microphone out.
The vibrator has an S on it. Slip something under it first, then push, then pull.
(second image) The antenna has two screws on the white part.
