주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Kodak DX3500 Digital Camera 수리는 저희 서비스 설명서를 사용하십시오.
  1. Kodak DX3500 Digital Camera  Teardown, The outside: 1 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, The outside: 1 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, The outside: 1 단계, 이미지 3/3
    • Some pretty pictures of the device! On the underside are the first two screws to remove!
  2. Kodak DX3500 Digital Camera  Teardown: 2 단계, 이미지 1/2 Kodak DX3500 Digital Camera  Teardown: 2 단계, 이미지 2/2
    • Open the battery compartment and you'll find 3 screws to remove.
    • Pry the bottom off and you'll see the internals! Yay!
  3. Kodak DX3500 Digital Camera  Teardown, Hmm... what next?: 3 단계, 이미지 1/2 Kodak DX3500 Digital Camera  Teardown, Hmm... what next?: 3 단계, 이미지 2/2
    • So, I looked at the bottom and nothing more was to be found. Flipped the camera about and found two screws on the outside at the back. Remove those and the rear case pops out.
  4. Kodak DX3500 Digital Camera  Teardown, The Motherboard: 4 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, The Motherboard: 4 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, The Motherboard: 4 단계, 이미지 3/3
    • Well, here's the mainboard. Time to remove screws. There's lots of them, but first, remove the one holding the display in.
    • Flip the display up and pry the two connectors away from the mainboard.
    • Then finally pry the power connector away.
  5. Kodak DX3500 Digital Camera  Teardown, Disconnecting the rest of the mainboard: 5 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, Disconnecting the rest of the mainboard: 5 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, Disconnecting the rest of the mainboard: 5 단계, 이미지 3/3
    • Well, now go haywire and remove every screw you see in the mainboard.
    • Then flip the board up and remove the data ribbon cable. (The Orange one). You have to flip up the small brown tab and slide the cable out.
    • Remove another power cable
    • Flipping open the battery cover reveals one of the many hidden screws in this assembly!
  6. Kodak DX3500 Digital Camera  Teardown, Lens + Peephole unit: 6 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, Lens + Peephole unit: 6 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, Lens + Peephole unit: 6 단계, 이미지 3/3
    • Time to remove all the screws again!
    • A couple of hidden ones, but once you get through them, you can pry the lens unit off of the camera, and take care with the ribbon cable here, it seems a bit delicate.
  7. Kodak DX3500 Digital Camera  Teardown, Secondary Board: 7 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, Secondary Board: 7 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, Secondary Board: 7 단계, 이미지 3/3
    • Easy peasy now, remove another power cable from the bottom.
    • Get to the next few screws as well.
  8. Kodak DX3500 Digital Camera  Teardown, Rear Case: 8 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, Rear Case: 8 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, Rear Case: 8 단계, 이미지 3/3
    • By this point enough screws should've come out and you can pry the front case away and take care with the ribbon again.
    • Flip up to the top and unscrew the board connected to the power button. Should be just one screw.
  9. Kodak DX3500 Digital Camera  Teardown, Front zoom unit: 9 단계, 이미지 1/2 Kodak DX3500 Digital Camera  Teardown, Front zoom unit: 9 단계, 이미지 2/2
    • Just disconnect the cable and then remove the 3 screws
    • It will come out in two parts.
  10. Kodak DX3500 Digital Camera  Teardown, I/O: 10 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, I/O: 10 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, I/O: 10 단계, 이미지 3/3
    • Flip over to the video out/mini USB port
    • Once again unscrew a 3 more screws and voila! We have an I/O board!
  11. Kodak DX3500 Digital Camera  Teardown, Disconnecting the last two boards: 11 단계, 이미지 1/3 Kodak DX3500 Digital Camera  Teardown, Disconnecting the last two boards: 11 단계, 이미지 2/3 Kodak DX3500 Digital Camera  Teardown, Disconnecting the last two boards: 11 단계, 이미지 3/3
    • Tired yet? You should be. So fiddly!
    • The boards are connected by 1 screw and a male/female connector between the two boards. Be careful here.
    • Unfortunately those hooks aren't just screwed in they're soldered on. You have to very carefully remove them from the battery unit.
  12. Kodak DX3500 Digital Camera  Teardown, And we're done!: 12 단계, 이미지 1/2 Kodak DX3500 Digital Camera  Teardown, And we're done!: 12 단계, 이미지 2/2
    • All is done. You can disconnect other sub-units down a bit more, but it's pretty straightforward. If you have a faulty flash you probably need to replace this entire board unit.
    • Note the large capacitor connected to the flash. Be VERY careful around this, it can hold a large amount of charge which could discharge into you, if you touch the ends, or into other electronics it comes in touch with.
    • Thanks for reading. This is my very first teardown, and I admit not all the images are great, need to get used to one handed photo taking. Hope this helps someone. I'm guessing most digital camera's of this type will have similar components!
Suchiththa Wickremesooriya
회원 가입일: 11/21/16
241 평판
안내서 1개 작성함
댓글 4개
a great start- you`ve made all my electronic devices very nervous should your teardown inspire me, lol!
- did you get it back togerther again?
look forward to seeing your next job ;}
jontyhawkes - 답글
I did not put it back together again, I couldn't bear the effort! I took things apart at a ridiculous level.... And yeah, the only reason I'm taking this apart is my building has electronics recycling in it, and I thought I'd take some stuff in and take them apart. Then I thought - why not turn them into a breakdown?
Suchiththa Wickremesooriya -
Congratulations on your first teardown. I hope you took care not to poke around the capacitor without first discharging it. It can hold a charge for a long time without a power source, and touching the terminals with your finger is not a pleasant experience (yes, it happened to me).
Kar Wong - 답글
Thanks very much! I did make sure not to mess with the capacitor. I did remember enough about electronics to recognise it and immediately placed it away from anything sensitive! I think I'll update the teardown with that!
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 1,556
