주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Krups ESSENZA Nespresso XN 2140 수리는 자사의 서비스 설명서를 사용하세요.
  1. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: 1 단계, 이미지 2개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: 1 단계, 이미지 2개 중 2개
    • Unplug the device from the mains to begin.
    • Remove the water container and tray.
  2. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: 2 단계, 이미지 2개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: 2 단계, 이미지 2개 중 2개
    • Remove the 4 bottom screws that hold the side panels. You need the oval drive bit for this.
    • Leave the other 2 bottom screws in place, these hold the bottom plate in place.
    • When reassembling, take care not to over tighten these screws. When in doubt, take 1/4 turn back.
    • Improvement: As these oval head screws are (intended to be) a nuisance, you may want to replace them with similar screws with a more common head.
  3. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 3 단계, 이미지 3개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 3 단계, 이미지 3개 중 2개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 3 단계, 이미지 3개 중 3개
    • Put the machine on one side, gently push the bottom edge of the side panel towards the top and lift it out.
    • Unhook the panel from the top.
    • Repeat with the other side panel.
    • The panels are identical, so there's no need to remember which was left or right.
    • When reassembling, make sure the bottom of the panel clicks fully closed before inserting the screws.
  4. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 4 단계, 이미지 3개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 4 단계, 이미지 3개 중 2개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 4 단계, 이미지 3개 중 3개
    • Use a Torx T120 to remove the two black screws that hold the lever, one on each side.
    • Open the lever and slide it upwards from its axle.
    • When reassembling, the axle needs to be turned vertical before you can slide the lever back into place.
  5. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 5 단계, 이미지 3개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 5 단계, 이미지 3개 중 2개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 5 단계, 이미지 3개 중 3개
    • Use a Torx T10 to remove the 2 screws that hold the cover of the brew unit at the front
    • Remove the last screw (T10) of the cover, located at the back and underside.
  6. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: 6 단계, 이미지 2개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: 6 단계, 이미지 2개 중 2개
    • Slide the brew unit cover back so that it comes free.
    • No force needed, some manipulation will do the trick.
  7. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 7 단계, 이미지 3개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 7 단계, 이미지 3개 중 2개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 7 단계, 이미지 3개 중 3개
    • Locate the clips that hold the brew unit, one on each side.
    • With your thumb(nail), push one sideways and and forward so that it frees the clip.
    • This takes a bit of force, but does not need to move the clip far.
    • Repeat on the other side.
  8. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the spout: 8 단계, 이미지 1개 중 1개
    • With both clips unlocked, remove the spout with a tilting downward motion.
    • When reassembling, you might want to temporarily loosen the front screws from the next step (9) to give the spout more room.
  9. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: 9 단계, 이미지 2개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: 9 단계, 이미지 2개 중 2개
    • Use a Torx T10 ro remove the 4 screws that hold the the brew unit, 2 on each side.
  10. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: 10 단계, 이미지 2개 중 1개 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: 10 단계, 이미지 2개 중 2개
    • Do NOT remove the hose
    • Lift the back of the brew unit.
    • Pull it backward until free.
    • Put it next to the machine, but do not put much strain on the hose.
    • Clean the spout, the front of the brew unit and anything that needs cleaning.
    • Once dry, it is ready to reassemble.
작성자
2다른 기여자 명과 함께
Altijd Ellende
회원 가입일: 03/29/21
237 평판
안내서 1개를 작성함
7가이드 댓글
Thanks, @farmyardgaming for cleaning up my grammar!
Altijd Ellende - 답글
Anytime, I'm glad I could help!
FarmYard Gaming -
Is it possible to change the o rings of the brew units?
Martin Müller - 답글
Hi Martin, I am not sure which o rings you refer to. Can you be more specific (photo perhaps)?
Altijd Ellende - 답글
Zeer fijn van deze info al gedaan en is terug in orde ok dank u.Marcel
Marcel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 122
지난 30일: 615
전체 시간: 14,591
