주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Kyocera Oystr 수리는 저희 서비스 설명서를 사용하십시오.
  1. Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 1/3 Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 2/3 Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 3/3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 1/3 Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 2/3 Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 3/3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 1/3 Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 2/3 Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 3/3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: 4 단계, 이미지 1/1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 1/3 Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 2/3 Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 3/3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: 6 단계, 이미지 1/1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
회원 가입일: 10/04/11
24 평판
안내서 2개 작성하였습니다
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G7
2 회원들
안내서 4개 작성하였습니다
댓글 2개
where do I get a new screen?
LARS ANDERSEN - 답글
where do i get a new screen
thanks
LARS ANDERSEN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 4,320
