주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
This will provide information on dissembling the phone to allow for repairs.
해당 분해도는 수리 안내서가 아닙니다. Kyocera Oystr 수리는 저희 서비스 설명서를 사용하십시오.
  1. Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 1/3 Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 2/3 Kyocera Oystr Teardown, Removing the battery: 1 단계, 이미지 3/3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over so that the front side is facing you. Flip open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 1/3 Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 2/3 Kyocera Oystr Teardown, Removing screws from screen: 2 단계, 이미지 3/3
    • Peel the Virgin Mobile sticker from the phone's screen, revealing two screws beneath it.
    • Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 1/3 Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 2/3 Kyocera Oystr Teardown, Exposing internal components: 3 단계, 이미지 3/3
    • Lift the plastic cover of the phone screen upwards by prying around the perimeter of the screen with a plastic opening tool.
    • After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place.
  4. Kyocera Oystr Teardown, Removing metal cover: 4 단계, 이미지 1/1
    • Remove metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 1/3 Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 2/3 Kyocera Oystr Teardown, Screen removal: 5 단계, 이미지 3/3
    • Remove the phone's speakers by using the plastic opening tool to pry up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: 6 단계, 이미지 1/1
    • Follow steps in reverse order to replace Kyocera Oystr’s screen.
David
회원 가입일: 2011년 10월 04일
24 평판
안내서 2개 작성하였습니다
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G7
2 회원들
안내서 4개 작성하였습니다
2 Comments
where do I get a new screen?
LARS ANDERSEN - 답글
where do i get a new screen
thanks
LARS ANDERSEN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 26
전체 시간: 4,184
