주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Flashlight 수리는 자사의 서비스 설명서를 사용하세요.
  1. LED touch light Teardown, LED touch light Teardown: 1 단계, 이미지 1개 중 1개
    • The assembled light.
  2. LED touch light Teardown: 2 단계, 이미지 1개 중 1개
    • Twist the mounting plate clockwise, then lift to remove it.
  3. LED touch light Teardown: 3 단계, 이미지 1개 중 1개
    • Remove the three AAA batteries from their holders.
  4. LED touch light Teardown: 4 단계, 이미지 1개 중 1개
    • Loosen and remove the four Phillips screws.
  5. LED touch light Teardown: 5 단계, 이미지 1개 중 1개
    • Having removed the four Phillips screws in the previous step, separate the assembly as shown.
  6. LED touch light Teardown: 6 단계, 이미지 1개 중 1개
    • Remove the three springs.
  7. LED touch light Teardown: 7 단계, 이미지 1개 중 1개
    • Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
  8. LED touch light Teardown: 8 단계, 이미지 1개 중 1개
    • Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
  9. LED touch light Teardown: 9 단계, 이미지 1개 중 1개
    • Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
  10. LED touch light Teardown: 10 단계, 이미지 1개 중 1개
    • Lift and separate the power switch from the main assembly.
  11. LED touch light Teardown: 11 단계, 이미지 1개 중 1개
    • Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
  12. LED touch light Teardown: 12 단계, 이미지 1개 중 1개
    • The separated lens, case and reflector elements.
  13. LED touch light Teardown: 13 단계, 이미지 1개 중 1개
    • The full assortment of separated parts.
작성자
2다른 기여자 명과 함께
Vimal
회원 가입일: 07/21/13
219 평판
안내서 1개를 작성함
3가이드 댓글
LED Flashlight is the best ever app i have ever use...I love it..
Kim Pal - 답글
flashlight is very important for android user.We are providing best flashlight with different feature.You can visit flashlight with extra feature,download and enjoy it.
https://play.google.com/store/apps/detai...
flash light - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 32
전체 시간: 4,107
