주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. LG G Watch R 수리는 저희 서비스 설명서를 사용하십시오.
  1. LG G Watch R Teardown, Front and Back: 1 단계, 이미지 1/2 LG G Watch R Teardown, Front and Back: 1 단계, 이미지 2/2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: 2 단계, 이미지 1/2 LG G Watch R Teardown, Removing the back cover: 2 단계, 이미지 2/2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: 3 단계, 이미지 1/2 LG G Watch R Teardown, Removing the Board: 3 단계, 이미지 2/2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: 4 단계, 이미지 1/2 LG G Watch R Teardown, The Battery: 4 단계, 이미지 2/2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: 5 단계, 이미지 1/1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: 6 단계, 이미지 1/3 LG G Watch R Teardown, P-OLED Panel: 6 단계, 이미지 2/3 LG G Watch R Teardown, P-OLED Panel: 6 단계, 이미지 3/3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
Dustin Richards
회원 가입일: 01/20/15
332 평판
안내서 1개 작성함
댓글 8개
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - 답글
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - 답글
Where could I find a battery for replacement?
Thanks in advance.
Fab - 답글
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 20,255
