주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. LG G5 수리는 자사의 서비스 설명서를 사용하세요.
  1. LG G5 Teardown, LG G5 Teardown: 1 단계, 이미지 2개 중 1개 LG G5 Teardown, LG G5 Teardown: 1 단계, 이미지 2개 중 2개
    • We're most interested in the G5's design, but some potent hardware lurks inside as well. Specs include:
    • 5.3-inch "Quad HD" IPS multi-touch display with 2,560 x 1,440 resolution (554 ppi)
    • Qualcomm Snapdragon 820 processor with Adreno 530 GPU and 4 GB RAM
    • Dual rear cameras (16 MP OIS primary and 8 MP wide-angle) and 8 MP front camera
    • 32 GB on-board storage, with expandable microSD card storage up to 2 TB
    • USB Type-C + 802.11 a/b/g/n/ac wi-fi + Bluetooth 4.2 + NFC + IR blaster
    • Fingerprint sensor + accelerometer + gyro + proximity sensor + barometer
    • Android 6.0 Marshmallow
  2. LG G5 Teardown: 2 단계, 이미지 2개 중 1개 LG G5 Teardown: 2 단계, 이미지 2개 중 2개
    • A quick comparison with last year's LG G4 shows off the G5's smoother, rounder, and more metallic exterior.
    • When stacked up against (or on top of) its older sibling, the G5 seems a bit chunkier than the G4. The G4 also felt nicer in the hand, and was a bit easier to grip.
    • Apparently, LG's move to a modular design and the use of the LM201 aluminum alloy forced them to step back from last year's slightly sleeker form factor. Still, we sense good things in store.
    • Is it just us, or does the G5 kinda look like Johnny 5?
  3. LG G5 Teardown: 3 단계, 이미지 3개 중 1개 LG G5 Teardown: 3 단계, 이미지 3개 중 2개 LG G5 Teardown: 3 단계, 이미지 3개 중 3개
    • We take a second to appreciate LG's little reminder that the G5 comes with a super-removable battery. How cute.
    • With the press of handy a button, we slide out the G5's battery module. Yep, removing the battery is even easier than it was on their last flagship phone.
    • Replaceable batteries make us happy. They play a huge role in minimizing the amount of e-waste associated with consumer electronics. Not to mention, they add the ability to carry an extra battery, so you don't run out of juice.
    • We doubt we'll hear of many G5's getting tossed out due to a dead battery.
  4. LG G5 Teardown: 4 단계, 이미지 3개 중 1개 LG G5 Teardown: 4 단계, 이미지 3개 중 2개 LG G5 Teardown: 4 단계, 이미지 3개 중 3개
    • We're ready to start pulling things apart, but we'll restrain ourselves just long enough for an X-ray scan. Our ingenious pals at Creative Electron show us what we're up against this round.
    • Do our X-ray eyes deceive us, or does this look a lot like an iPhone? Well, except for that snappy removable battery, of course.
    • Small metal backing in the center of the phone, logicmotherboard stage right, battery at center left—could it be phone Feng Shui?
    • An X-ray lineup confirms the G5 almost perfectly splits the difference between the iPhone 6 (left) and 6 Plus (right).
    • Looks like that end-cap module is more than just a battery holder and USB. Time to pop that sucker open.
  5. LG G5 Teardown: 5 단계, 이미지 2개 중 1개 LG G5 Teardown: 5 단계, 이미지 2개 중 2개
    • It takes a pretty serious tug to decouple the G5's battery from its module—probably not something you'll do by accident.
    • The 3.85 V, 10.8 Wh, Li-Ion battery in the G5 weighs in at 2800 mAh—just edging out the 2750 mAh cell in the iPhone 6s Plus...
    • But, it's a slight capacity decrease from the 3000 mAh whoppers we found in the G5's predecessor and Samsung's recent Galaxy S7.
    • Our guess? LG is banking on their customers taking advantage of that replaceable battery to swap on the go if needed, negating the need for a super-huge capacity.
  6. LG G5 Teardown: 6 단계, 이미지 3개 중 1개 LG G5 Teardown: 6 단계, 이미지 3개 중 2개 LG G5 Teardown: 6 단계, 이미지 3개 중 3개
    • Okay, but what's in the module itself?
    • Probably magic.
    • And glue. The front and back module covers are very well glued in place.
    • Plasticgate 2016 update: That small front cover is plastic, but the rear one is certainly fancy aluminum.
    • Picking apart the module reveals a few screws, some glue, and a surprising amount of goodies awaiting perusal.
    • In addition to making USB port replacements easier than ever, the tiny battery module also contains a speaker, some antennas, and a lot of spring contacts.
  7. LG G5 Teardown: 7 단계, 이미지 2개 중 1개 LG G5 Teardown: 7 단계, 이미지 2개 중 2개
    • As it sinks in that we've removed the battery without opening the phone, we turn our attention to the SIM card.
    • A single tray houses both the SIM card and microSD card.
    • Though the G5 doesn't support Android's adoptable storage, LG holds to their tradition of including external storage in their flagship phones—another win for longevity and, in all likelihood, a net reduction in e-waste.
    • Yes, the day will probably come when 2 TB of storage in your smartphone just isn't nearly enough. But right now, that day looks comfortably far off.
  8. LG G5 Teardown: 8 단계, 이미지 3개 중 1개 LG G5 Teardown: 8 단계, 이미지 3개 중 2개 LG G5 Teardown: 8 단계, 이미지 3개 중 3개
    • After just two screws and some pry-able clips, we pop open the display with ease. No fuss, no adhesive.
    • It's a decidedly iPhone-esque display opening, in the best possible way—or at least, it's much like how iPhone display removal used to go, before all that adhesive crashed the party.
    • Really though, regardless of the insides, LG has finally figured out the modular unibody. The display is seamlessly mounted in the rear case, making for a luxury feel—while still maintaining battery access. We hope this trend catches on.
    • What's better than a user-removable battery? Why, a user-removable battery with a mechanical shock absorber.
    • This springy mechanical doodad helps the G5's battery slide perfectly into its parking space, and gives a satisfying tactile snick as you click it into place.
  9. LG G5 Teardown: 10 단계, 이미지 3개 중 1개 LG G5 Teardown: 10 단계, 이미지 3개 중 2개 LG G5 Teardown: 10 단계, 이미지 3개 중 3개
    • With the display out and the battery removed right from the get, the chassis has little to hide: vibrator motor, headphone jack, and buttons are all that remain. Time to drain the tub.
    • A hefty and very well-adhered metal plate keeps the back button pressed to the case, and probably adds ingress proofing. (It also reminds us a bit of the bi-metal Apple logo.)
    • The G5's fingerprint sensor is a little different than the one we found in the LG-made Nexus 5X, but it houses a familiar set of spring contacts.
  10. LG G5 Teardown: 11 단계, 이미지 2개 중 1개 LG G5 Teardown: 11 단계, 이미지 2개 중 2개
    • Out comes one front-facing camera and one (of two) rear-facing cameras—hooray modularity!
    • That big shiny one is the primary 16 MP rear camera, with extra girth to accommodate the optical image stabilization mechanism.
    • The third and final camera—the auxiliary 8-MP rear shooter with the trick wide-angle lens—is trapped helplessly under the motherboard, so we'll come back to these guys in just a moment.
  11. LG G5 Teardown: 12 단계, 이미지 3개 중 1개 LG G5 Teardown: 12 단계, 이미지 3개 중 2개 LG G5 Teardown: 12 단계, 이미지 3개 중 3개
    • Let's pop that motherboard off and snag the final camera for a family photo! From left to right:
    • Like the G of yesteryear, the G5 sports a 16 MP, ƒ/1.8 camera with a 1/2.6" image sensor.
    • LG also packed in a 135-degree, wide-angle camera with an ƒ/2.4 aperture and 8 MP image sensor—perfect for your tiger jumping photo shoots.
    • Matching last year's selfie shooter, a wee 8 MP front-facing camera rounds out the trio.
    • IC Identification:
    • Invensense ICG-1020S 2-Axis MEMS OIS Gyroscope
    • Rohm BU24234 OIS Driver
  12. LG G5 Teardown: 13 단계, 이미지 1개 중 1개
    • There’s been a lot of talk about the G5’s new aluminum alloy, but let’s take a look at its silicon:
    • Samsung K3RG2G20BM-MGCJ 4 GB LPDDR4 RAM with quad-core Qualcomm Snapdragon 820 SOC layered beneath
    • Samsung KLUBG4G1CE-B0B1 32 GB MLC Universal Flash Storage 2.0
    • NXP Semiconductor 54802 (PN548) NFC Controller
    • Qualcomm SMB1350 Quick Charge 3.0 IC
    • Analogix SlimPort ANX7816 Ultra-HD Transmitter
    • Analogix SlimPort ANX7418 USB-C Switch/Controller
    • Qualcomm WSA8815 4 W Class-D Audio Amplifier
  13. LG G5 Teardown: 14 단계, 이미지 1개 중 1개
    • More chip goodness on the rear of the motherboard:
    • Broadcom BCM43455 5G Wi-Fi Combo Chip
    • Qualcomm WTR3925 LTE Transceiver
    • Avago ACPM-7788 Multiband Multimode Power Amplifier
    • Skyworks SKY77814-11 LTE Power Amplifier Module
    • Skyworks SKY13560 RF Switch
    • Qualcomm PM8996 Power Management IC
    • Qualcomm PMI8996 Power Management IC
  14. LG G5 Teardown: 15 단계, 이미지 2개 중 1개 LG G5 Teardown: 15 단계, 이미지 2개 중 2개
    • IC Identification, pt. 2:
    • Bosch Sensortec BMI120 3-axis accelerometer/gyroscope
    • Rohm hall sensor
    • ON Semiconductor FSUSB104UMX 2-Port, 480 Mbps USB 2.0 switch
    • Knowles MEMS microphone
    • Skyworks SKY13351-378LF GaAs SPDT switch
    • Qualcomm QFE2101 antenna tuner (likely)
  15. LG G5 Teardown: 16 단계, 이미지 1개 중 1개
    • As a final treat, we take a closer look at the (unsurprisingly LG-manufactured) display. Its cable has some chips and markings (like a Macronix MX25V1006E 1 Mb serial flash memory)—and we've got a speaker, and a smattering of contacts.
    • A closer look at the display cable reveals that this G5 apparently has a name: Alice.
    • We're not going any further down this rabbit hole; we have a score to assign!
  16. LG G5 Teardown: 17 단계, 이미지 2개 중 1개 LG G5 Teardown: 17 단계, 이미지 2개 중 2개
    • LG G5 Repairability Score: 8 out of 10 (10 is easiest to repair)
    • The user-removable, slide-out battery is a huge boon to phone lifespan.
    • No glue and few screws make for a relatively simple opening procedure.
    • Standard Phillips #00 screws means the right tool is probably already in your toolbox.
    • Many components are modular, making for easier, cheaper part replacement.
    • Module covers are glued on, making repairs a bit sticky—but the module itself greatly simplifies the process of replacing a faulty USB port.
    • The fused display assembly will need to be replaced if the LCD or glass breaks, increasing costs.
댓글 90개
very good teardown! it's nice to see a flagship-phone with this score. much better than Samsung S7/S7edge. Kudos LG
Peter Lang - 답글
One thing I have done on my previous LG's is to replace the camera lense (or rather, glass facing outwards). They usually become more and more scratched, leading to lower quality photos with time. This wasn't mentioned, is it possible? I assume both lift right out with the black rectangle thingy in the back shell?
erik - 답글
I solved this problem using a plastic watch polish paste.
It's not actually the glass that scratches. As far as I know the glass used is sapphire glass that is extremely scratch resistant. It's the oleophobic coating which can be polished away.
This worked with my lg g2 anyways..
Used "polywatch" bought on German amazon. Not sure if sold worldwide.
Malo M -
I need to figure out how to replace that outward facing glass over the camera myself. Shattered inside the case...if anyone can lead me to the right piece, and process?
Chris Klopfenstein -
Yes, I ordered a replacement on Amazon for like $15, cracked open my phone, carefully peeled out the glass, and popped in the new one. Little muss or fuss, and my picture quality is as good as new!
J. Jones -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 128
전체 시간: 277,946
