I have tried to include as much detail as possible in this teardown. I have even inspected the chips on the mainboard! Thanks for looking, and I hope you find this useful.
해당 분해도는 수리 안내서가 아닙니다 . LG GW300 수리는 저희 서비스 설명서 를 사용하십시오.
Get a thin opening tool and slide it around the bezel of the device.
Make sure you put it in the correct place, behind the silver bezel of the front of the phone!
The front and back of the device should separate.
Two buttons should come off after you have removed the back.
This is the rear speaker.
Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
These buttons are soldered to the mainboard so make sure you don't break them!
The front speaker also has to be pried from the front housing.
The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
The ribbon cable can then be take out of the connector
The ribbon connector is very fragile, so be careful when lifting the lever.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
