소개
The LG Rumor is a full QWERTY keyboard slider phone available from Sprint in 2008. It has an SD card slot and runs a unique OS.
필요한 것
The LG Rumor, This phone is the broken phone that I can't seem to fix also depicted here: Turns on, then shuts off right after
The Logic board:
The CPU is a Qualcomm MSM6100 ARM Processor
The RAM, it is manufactured by Hynix
The Camera 1.3MP, not bad
The SD Card Slot:
Speaker [Speakerphone]
Headphone Jack:
Battery Contacts:
I'm a noob too all this but I have this phone. It's not activated & replaced because the charging port on the phone is not working. I have tried many different wall/car charges and it just won't connect. I'm thinking it may have been dropped one too many times and the solder may just be broken. Did you do a break down of this area?
Now, flip this tab up, towards the bottom of the phone, and remove the speaker/side-button cable.
Now, slowly lift the cable up, minding the adhesive on the back.
When you come to the buttons, be especially careful, and when you get to the speaker, use a flathead screwdriver, and pop the speaker out.
댓글 2개
I'd recommend not opening the screen bit in any way shap or form.
I tore down an AX260. Tear down is identical. I removed the screen, too. I heated the entire glass with a variable heat gun set to approximately 140F. I monitored the temperature of the glass with a non contact infrared thermometer. At just under 140F the screen separated from the glass on three sides. I hinged the screen and applied the heat to the remaining adhesive. As it warmed the adhesive disengaged from the screen intact. The adhesive acts like a sticky foam. Screen was clean with no adhesive residue and would be easy replace glass or screen at that point.
Thank you for a very nice tear down guide.
