주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. LG T310 수리는 저희 서비스 설명서를 사용하십시오.
  1. LG T310 Teardown, LG T310 Teardown: 1 단계, 이미지 1/1
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: 2 단계, 이미지 1/2 LG T310 Teardown: 2 단계, 이미지 2/2
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: 3 단계, 이미지 1/1
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: 4 단계, 이미지 1/2 LG T310 Teardown: 4 단계, 이미지 2/2
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
회원 가입일: 11/07/13
116 평판
안내서 1개 작성함
University of Maryland, Team 1-5, Calloway Fall 2013 University of Maryland, Team 1-5, Calloway Fall 2013 회원
UMD-CALLOWAY-F13S1G5
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,391
