주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. LG Tribute Royal 수리는 저희 서비스 설명서를 사용하십시오.
  1. LG Tribute Royal Teardown, Remove back panel: 1 단계, 이미지 1/3 LG Tribute Royal Teardown, Remove back panel: 1 단계, 이미지 2/3 LG Tribute Royal Teardown, Remove back panel: 1 단계, 이미지 3/3
    • Use a spudger to open the back panel and disconnect it from the phone.
  2. LG Tribute Royal Teardown, Unscrew all the screws: 2 단계, 이미지 1/2 LG Tribute Royal Teardown, Unscrew all the screws: 2 단계, 이미지 2/2
    • Unscrew all 16 screws holding the back panel cover on to the phone
  3. LG Tribute Royal Teardown, Remove back cover: 3 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove back cover: 3 단계, 이미지 2/2
    • Apply adequate force to the back panel to remove it from the phone
  4. LG Tribute Royal Teardown, Remove battery: 4 단계, 이미지 1/3 LG Tribute Royal Teardown, Remove battery: 4 단계, 이미지 2/3 LG Tribute Royal Teardown, Remove battery: 4 단계, 이미지 3/3
    • Disconnect the ribbon cable that connects the battery to the motherboard. I suggest you heat up the battery first because of the glue and not do what i did. Use spudger to pry up the battery from the device.
  5. LG Tribute Royal Teardown, Remove back camera: 5 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove back camera: 5 단계, 이미지 2/2
    • Disconnect the back camera from the motherboard by disconnecting the connector from the motherboard
  6. LG Tribute Royal Teardown, Remove front camera: 6 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove front camera: 6 단계, 이미지 2/2
    • Disconnect the front camera from the phone by disconnecting the ribbon cable from the front camera attached to the motherboard.
  7. LG Tribute Royal Teardown, Disconnect display: 7 단계, 이미지 1/2 LG Tribute Royal Teardown, Disconnect display: 7 단계, 이미지 2/2
    • Disconnect the display ribbon cable from the motherboard.
  8. LG Tribute Royal Teardown, Remove motherboard: 8 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove motherboard: 8 단계, 이미지 2/2
    • To remove the motherboard apply adequate pressure because there will be some resistance. Try to avoid as much thermal paste as you can.
  9. LG Tribute Royal Teardown, Remove sim card and holder: 9 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove sim card and holder: 9 단계, 이미지 2/2
    • To remove sim card just push it out the side. The sim card will be in the holder.
  10. LG Tribute Royal Teardown, Remove Vibrator Motor: 10 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove Vibrator Motor: 10 단계, 이미지 2/2
    • Disconnect the ribbon cable holding down the vibrator motor then remove it.
  11. LG Tribute Royal Teardown, Remove Speaker: 11 단계, 이미지 1/1
    • Remove the speaker at the top of the phone.
  12. LG Tribute Royal Teardown, Remove microphones: 12 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove microphones: 12 단계, 이미지 2/2
    • Remove microphones
  13. LG Tribute Royal Teardown, Remove side buttons: 13 단계, 이미지 1/2 LG Tribute Royal Teardown, Remove side buttons: 13 단계, 이미지 2/2
    • Remove the side buttons by disconnecting the ribbon cables on each one.
  14. LG Tribute Royal Teardown, Reassemble the phone: 14 단계, 이미지 1/1
    • Follow the steps backwards in order to reassemble the phone.
    • Be sure to clean the sim card with compressed air or else it wont work
Rose Schneider
회원 가입일: 05/01/21
413 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 715
