주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. LG VX8350 Repair 수리는 저희 서비스 설명서를 사용하십시오.
  1. LG VX8350 Teardown, Battery: 1 단계, 이미지 1/2 LG VX8350 Teardown, Battery: 1 단계, 이미지 2/2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. LG VX8350 Teardown: 2 단계, 이미지 1/2 LG VX8350 Teardown: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. LG VX8350 Teardown, Circuit Board Housing: 3 단계, 이미지 1/3 LG VX8350 Teardown, Circuit Board Housing: 3 단계, 이미지 2/3 LG VX8350 Teardown, Circuit Board Housing: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. LG VX8350 Teardown: 4 단계, 이미지 1/2 LG VX8350 Teardown: 4 단계, 이미지 2/2
    • Lift the back cover starting at the bottom of the phone.
  5. LG VX8350 Teardown: 5 단계, 이미지 1/2 LG VX8350 Teardown: 5 단계, 이미지 2/2
    • Remove the back cover completely from the phone.
  6. LG VX8350 Teardown, Circuit Board: 6 단계, 이미지 1/1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. LG VX8350 Teardown: 7 단계, 이미지 1/2 LG VX8350 Teardown: 7 단계, 이미지 2/2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. LG VX8350 Teardown, Keypad: 8 단계, 이미지 1/2 LG VX8350 Teardown, Keypad: 8 단계, 이미지 2/2
    • Lift the keyboard and remove it from the phone.
  9. LG VX8350 Teardown, Screen Cover: 9 단계, 이미지 1/3 LG VX8350 Teardown, Screen Cover: 9 단계, 이미지 2/3 LG VX8350 Teardown, Screen Cover: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
  10. LG VX8350 Teardown: 10 단계, 이미지 1/3 LG VX8350 Teardown: 10 단계, 이미지 2/3 LG VX8350 Teardown: 10 단계, 이미지 3/3
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
  11. LG VX8350 Teardown, LG VX8350 Teardown: 11 단계, 이미지 1/1
    • You have now performed a complete teardown of the LG VX8350.
Jonathan Flowers
회원 가입일: 10/18/13
607 평판
안내서 6개 작성하였습니다
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 회원
CLEM-BENSON-F13S14G7
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 1,520
