소개
How-To remove the internal hard drive contained within the external enclosure.
필요한 것
다른 4명이 해당 안내서를 완성하였습니다.
댓글 6개
Thank you !
We will need it ....
Drive inside say
5VDC / 12VDC - 0.5A 0.7A
But my replace say:
5VDC, 0,60A
12VDC, 0,45A
Is that OK or should I not change?
hlundstedt - 답글
thank you this was great help.
I have a problem where the usb port is broken on the inside of the hard drive. do you know what that piece is called? i need to buy a new one, not even sure if its possible to buy.
thank you
its the first green rectangle shape that has the USB attatched to it which is broken.
sorry not really good with this stuff just trying to solve it
Thanks, very clear manual, helped me wel ! :)
Top notch, thanks
