주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Lennox Y0349 Thermostat 수리는 저희 서비스 설명서를 사용하십시오.
  1. Lennox Y0349 Thermostat Teardown, Thermostat: 1 단계, 이미지 1/1
    • Here is the Lennox Y0349.
  2. Lennox Y0349 Thermostat Teardown, Remove the Thermostat from the Wall: 2 단계, 이미지 1/1
    • Pushing in at the bottom of the thermostat, pull down and remove the thermostat from the wall. Note: the circuit breaker for the HVAC system MUST be off. Use caution when handling electrical wires.
  3. Lennox Y0349 Thermostat Teardown, Remove the Back Plate: 3 단계, 이미지 1/2 Lennox Y0349 Thermostat Teardown, Remove the Back Plate: 3 단계, 이미지 2/2
    • Locate the plastic tabs, and using a flat headed screwdriver, push them inward. This may take some force, but the plastic should give fairly easily.
  4. Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 4 단계, 이미지 1/3 Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 4 단계, 이미지 2/3 Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 4 단계, 이미지 3/3
    • The board is exposed! Now simply push back the plastic tabs connecting the board and disconnect the cables
  5. Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 5 단계, 이미지 1/3 Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 5 단계, 이미지 2/3 Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 5 단계, 이미지 3/3
    • Now that the board is removed, we see 8 3 volt relays, the temperature and humidity sensor (on it's own board) a small battery, and the microprocessor.
    • The screen has 3 cables (the wide one is for the LCD, the skinny one if for the digitizer, and the simple, red and black one is for the backlighting.
  6. Lennox Y0349 Thermostat Teardown, Open the Display: 6 단계, 이미지 1/1
    • The screen and be opened to expose the LCD and the backlighting
    • You've opened the Lennox Y049 Thermostat (or another similar model).
teardown-er
회원 가입일: 02/20/21
537 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 47
전체 시간: 2,539
