주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Lenovo Ideatab A1000 수리는 저희 서비스 설명서를 사용하십시오.
  1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 1 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 1 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 1 단계, 이미지 3/3
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 2 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 2 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 2 단계, 이미지 3/3
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 3 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 3 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 3 단계, 이미지 3/3
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 4 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 4 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 4 단계, 이미지 3/3
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 5 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 5 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 5 단계, 이미지 3/3
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 6 단계, 이미지 1/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 6 단계, 이미지 2/3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: 6 단계, 이미지 3/3
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 2개
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - 답글
Thanks for this guide!
Pooshon Banerjee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 14,213
