주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Lenovo ThinkPad X1 Yoga 수리는 저희 서비스 설명서를 사용하십시오.
  1. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: 1 단계, 이미지 3/3
    • Here we have the screen as just removed from our Thinkpad.
    • In the lower corners you will find two rubber caps with hidden screws.
    • Remove the caps and unscrew the first screw.
  2. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: 2 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: 2 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: 2 단계, 이미지 3/3
    • You have to remove the screws on the right and left side to proceed.
  3. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: 3 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: 3 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: 3 단계, 이미지 3/3
    • The screws secured this rubbery, bendy cover which is removed easily by using your fingernails or a spudger.
    • When you have removed the cover store it away somewhere safe.
    • Remove the two PH1 screws marked with red circles.
  4. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: 4 단계, 이미지 3/3
    • Flip the display on the side. This way it is easier to pull out the plastic caps holding the display wires in place.
    • Use some tweezers to lever out the plastic cap and store it somewhere safe.
    • Gently pull out the cables from the hinge.
  5. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: 5 단계, 이미지 3/3
    • To the right you'll have to repeat the steps.
    • Free the cables from their prison in the hinge.
  6. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Rubber frame: 6 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Rubber frame: 6 단계, 이미지 2/2
    • The screen is secured by a rubber frame which is glued onto the display cover.
    • Use a guitar pick or a spuder to lift it off. In my case the glue was not really strong and required no heat.
  7. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: 7 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: 7 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: 7 단계, 이미지 3/3
    • One flex connector is reachable for us. Lift up the brass clip.
    • With the screws removed and the clip detached the display is now free
    • Be careful not to rip the other flex connector, we have to detach in the next steps.
  8. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: 8 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: 8 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: 8 단계, 이미지 3/3
    • Pull the display up about an inch just so that you can detach the flex cables with the levers / clips.
  9. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: 9 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: 9 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: 9 단계, 이미지 3/3
    • With all reachable connectors detached you can now lift up the screen from the cover but we're not quite there yet.
    • Flip over the screen like seen in the second picture.
    • Detach the last connector between cover and screen.
  10. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Done!: 10 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Done!: 10 단계, 이미지 2/2
    • With the last connector removed you're done!
    • You could now replace the screen or continue the disassambly.
Fred
2,837 평판
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 75
전체 시간: 1,102
