주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Lenovo W600 Keyboard 수리는 저희 서비스 설명서를 사용하십시오.
  1. Lenovo W600 Keyboard Teardown, Removing the backplate: 1 단계, 이미지 1/2 Lenovo W600 Keyboard Teardown, Removing the backplate: 1 단계, 이미지 2/2
    • Take off the protective stickers on the four corners
    • Use a Phillips screwdriver to remove all five screws on the keyboard
    • Insert a word screwdriver into one corner and move around to break all the hot glue. You may need to use steel rulers to break the hot glue between the keys and the backplate.
    • After struggling for a while you should be able to take the backplate off.
  2. Lenovo W600 Keyboard Teardown, Removing the keys' backplate: 2 단계, 이미지 1/2 Lenovo W600 Keyboard Teardown, Removing the keys' backplate: 2 단계, 이미지 2/2
    • Unplug the FPC cable.
    • Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • No more teardown process is possible without breaking the case of the keyboard.
_ Lithane
회원 가입일: 08/18/17
101 평판
안내서 1개 작성함
댓글 한 개
i am experiencing a problem with my levovo w700 laptop keyboard. it is the problem as seen in this youtube vid - https://youtu.be/qmMcfFHCM60
any solutions.
i am using windows 7
Mr Keith S Boyd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 805
