주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Lenovo Yoga 730-13IKB 수리는 저희 서비스 설명서를 사용하십시오.
    • Insert wisdom here.
  1. Lenovo YOGA 730 13" Teardown: 2 단계, 이미지 1/3 Lenovo YOGA 730 13" Teardown: 2 단계, 이미지 2/3 Lenovo YOGA 730 13" Teardown: 2 단계, 이미지 3/3
IT FIX
회원 가입일: 10/16/17
6,340 평판
안내서 74개 작성하였습니다
댓글 9개
Guten Tag. könnten Sie mir bitte sagen. wo man ein Ersatzscharnier rechts für das Modell Lenovo Yoga 730-13IKB , Core i5-8250U, 8GB RAM, 256GB SSD (81CT0023GE) finden kann? Danke im Voraus für Ihre Antwort.
Iurie Ciobanu - 답글
Why didn’t you completly pull the board out and show the cpu? Is it removable and upgradable?
Braheem Hazeem (Grumpy Wolf) - 답글
Most laptop cpu’s are soldered to their contacts. There’s very few models of laptop’s that will have removable cpu’s in the consumer market.
Matthew Dixon -
I’ve the yoga 30 13 inch FHD touchscreen. Anyone know if the 40 pin connector on the board would support a UHD touchscreen upgrade?
JT Cen - 답글
Teardown to me mean you strip it completely down to loose parts. This did not help me at all with removing the screen to replace hinges. This “teardown” is something a rookie should have made. I expect better ifixit.
bw_b_dub - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 32
전체 시간: 14,023
