주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Linksys BEFW11S4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Linksys BEFW11S4 Teardown, Linksys BEFW11S4 Teardown: 1 단계, 이미지 1/1
    • Waiting to be disassembled...
  2. Linksys BEFW11S4 Teardown: 2 단계, 이미지 1/3 Linksys BEFW11S4 Teardown: 2 단계, 이미지 2/3 Linksys BEFW11S4 Teardown: 2 단계, 이미지 3/3
    • Remove antennas.
    • Remove nuts and washers around antenna connectors.
    • Push in antenna connectors.
  3. Linksys BEFW11S4 Teardown: 3 단계, 이미지 1/3 Linksys BEFW11S4 Teardown: 3 단계, 이미지 2/3 Linksys BEFW11S4 Teardown: 3 단계, 이미지 3/3
    • Remove feet (with flat-head screwdriver, fingernails, etc).
    • Unscrew the screws.
  4. Linksys BEFW11S4 Teardown: 4 단계, 이미지 1/2 Linksys BEFW11S4 Teardown: 4 단계, 이미지 2/2
    • Pull apart blue front from black back with a LOT of force.
    • Slide and pull up bottom. (Make sure the antenna connectors get through.)
  5. Linksys BEFW11S4 Teardown: 5 단계, 이미지 1/1
    • Twist and pull out antenna connector feeds.
  6. Linksys BEFW11S4 Teardown: 6 단계, 이미지 1/3 Linksys BEFW11S4 Teardown: 6 단계, 이미지 2/3 Linksys BEFW11S4 Teardown: 6 단계, 이미지 3/3
    • Pull up RF shield from motherboard.
    • Unscrew the motherboard from the bottom.
    • Push the motherboard forward (as in this picture) to unlatch it from the bottom.
  7. Linksys BEFW11S4 Teardown: 7 단계, 이미지 1/2 Linksys BEFW11S4 Teardown: 7 단계, 이미지 2/2
    • Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
    • Push the card forward to deattach the pins.
    • Remove the card from the metal holdster.
  8. Linksys BEFW11S4 Teardown: 8 단계, 이미지 1/1
    • Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
    • Macronix 29F040QC-90
    • ISSI IS41C16100S-50K
    • SAMSUNG ARM S3C4510X01-QERO
    • RMC RTL8019AS
    • Bothhands FB2022
    • Bothhands 40ST1041E
    • Kendin KS8995. Kendin has since been bought by Micrel.
  9. Linksys BEFW11S4 Teardown: 9 단계, 이미지 1/1
    • Enjoy!
William McKinnerney
회원 가입일: 04/18/10
65 평판
안내서 1개 작성함
댓글 2개
what is that card inside this router
hartiTube - 답글
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 25
전체 시간: 9,059
