주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Linksys router WRT54G2 V1 수리는 저희 서비스 설명서를 사용하십시오.
  1. Linksys WRT54G2 V1 Teardown, Getting Ready!: 1 단계, 이미지 1/2 Linksys WRT54G2 V1 Teardown, Getting Ready!: 1 단계, 이미지 2/2
    • looks like my desk is a mess! Time to clean up!
    • This may take a while.
  2. Linksys WRT54G2 V1 Teardown: 2 단계, 이미지 1/2 Linksys WRT54G2 V1 Teardown: 2 단계, 이미지 2/2
    • Much Better.
    • The lighting looks good with minifigure holding a spudger.
    • Do not attempt to make a minifigure hold a spudger. he could fall over and get hurt.
  3. Linksys WRT54G2 V1 Teardown, Actually being productive.: 3 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, Actually being productive.: 3 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, Actually being productive.: 3 단계, 이미지 3/3
    • this is the linksys WRT54G2 V1.
    • The Internet in jack.
    • The 4 Ethernet out jacks
    • One reset button.
    • One 12 Volt DC .5 amp inlet.
    • 1 WPS button.
  4. Linksys WRT54G2 V1 Teardown, Taking it apart!: 4 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, Taking it apart!: 4 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, Taking it apart!: 4 단계, 이미지 3/3
    • This is the back of the router. and 4 of its screws must be removed
    • WHAT IS THIS? A new screw!
    • Nothing but the best equipment to tackle this! @kelsea recommended I should use my tools more.
  5. Linksys WRT54G2 V1 Teardown, Resistance: 5 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, Resistance: 5 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, Resistance: 5 단계, 이미지 3/3
    • I feel a disturbance in this repair...
    • AHA! its darth voider! WE MUST DESTROY HIM!
    • iFixit emerges once again! VICTORY!
  6. Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 6 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 6 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • How do we open this? Rip it open? No... As tempting as that is there must be a more elegant way...
    • iFixit tools are elegant right? Use a iFixit Opening Tool to do the trick. mostly in the back corners.
    • The cover seems to pop back with nothing holding it. I used a screw from the router to hold it.
  7. Linksys WRT54G2 V1 Teardown: 7 단계, 이미지 1/1
    • only popping the back corners does not appear to be enough.
    • The front area seems stronger, and it feels like it may snap my opening tool. onto the big guns!
  8. Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 8 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 8 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    구매
    • Engraved with the word IFIXIT to show authenticity.
    • Made with REAL metal
    • Look at that obviously not edited in shine!
    • Luckily I own one of these beauties. you can buy one too! BUY THE SPUDGENATOR 9000 HERE!
  9. Linksys WRT54G2 V1 Teardown: 9 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown: 9 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown: 9 단계, 이미지 3/3
    • insert the SPUDGENATOR 9000 and slide it through the split until you here pops.
    • POP!
    • POP!
    • POP!
    • Eventually it will open.
  10. Linksys WRT54G2 V1 Teardown: 10 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown: 10 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown: 10 단계, 이미지 3/3
    • Here is the back of the WPS button.
    • These tabs are held in too much for my fingers to get! Time for the SPUNGENATOR 9000! use it to pry those tough tabs.
    • Aaaaand its out! (after breaking a tab)
  11. Linksys WRT54G2 V1 Teardown: 12 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown: 12 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown: 12 단계, 이미지 3/3
    • Removal of the logic board motherboard includes no screws.
    • I'm not removing the motherboard because that would involve cutting the wires, and I want to use this later! (not in the mood for soldering today. =p)
  12. Linksys WRT54G2 V1 Teardown, THE END!: 13 단계, 이미지 1/2 Linksys WRT54G2 V1 Teardown, THE END!: 13 단계, 이미지 2/2
    • All the parts.
    • Thumbs up not included.
  13. Linksys WRT54G2 V1 Teardown, SETUP: 14 단계, 이미지 1/3 Linksys WRT54G2 V1 Teardown, SETUP: 14 단계, 이미지 2/3 Linksys WRT54G2 V1 Teardown, SETUP: 14 단계, 이미지 3/3
Aiden
회원 가입일: 09/19/15
17,429 평판
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 2,072
