주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show the teardown of a Linksys WAG200G gateway.
해당 분해도는 수리 안내서가 아닙니다. Linksys WAG200G 수리는 저희 서비스 설명서를 사용하십시오.
  1. Turn the router with the bottom facing upwards and locate the 4 feet. Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
    • Turn the router with the bottom facing upwards and locate the 4 feet.
    • Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
    • The front of the case can be disconnected from the backside now.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  3. The antenna cable is soldered to the board. It can be unsoldered or just cut. Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
    • The antenna cable is soldered to the board. It can be unsoldered or just cut.
    • Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
  4. The board can now be removed from the case easily.
    • The board can now be removed from the case easily.
    • 10/100 Base-T Dual Port Transformer: HN2064CG
    • CPU: TNETD7200ZDW
    • 10/100 Ethernet Switch : 88E6060-RCJ1
knipwim
회원 가입일: 2018년 09월 01일
1,968 평판
안내서 19개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 833
