주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Logitech 2-MP Webcam C600 수리는 저희 서비스 설명서를 사용하십시오.
  1. Logitech 2-MP Webcam C600 Teardown, Teardown: 1 단계, 이미지 1/3 Logitech 2-MP Webcam C600 Teardown, Teardown: 1 단계, 이미지 2/3 Logitech 2-MP Webcam C600 Teardown, Teardown: 1 단계, 이미지 3/3
  2. Logitech 2-MP Webcam C600 Teardown: 2 단계, 이미지 1/3 Logitech 2-MP Webcam C600 Teardown: 2 단계, 이미지 2/3 Logitech 2-MP Webcam C600 Teardown: 2 단계, 이미지 3/3
    • Pry off the button mounted on the side
    • Green arrow indicates the location of screw hole
    • Use a #0 Phillips head screwdriver to remove the screw
  3. Logitech 2-MP Webcam C600 Teardown: 3 단계, 이미지 1/3 Logitech 2-MP Webcam C600 Teardown: 3 단계, 이미지 2/3 Logitech 2-MP Webcam C600 Teardown: 3 단계, 이미지 3/3
    • Remove the screw indicated by the green arrows
    • The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
  4. Logitech 2-MP Webcam C600 Teardown: 4 단계, 이미지 1/3 Logitech 2-MP Webcam C600 Teardown: 4 단계, 이미지 2/3 Logitech 2-MP Webcam C600 Teardown: 4 단계, 이미지 3/3
    • The screws indicated by the blue arrows hold the lens module in place
    • The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
  5. Logitech 2-MP Webcam C600 Teardown: 5 단계, 이미지 1/2 Logitech 2-MP Webcam C600 Teardown: 5 단계, 이미지 2/2
    • Attached to the white plastic is the privacy shade position sensor.
    • The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
    • The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
I Heart Robotics
회원 가입일: 11/09/09
210 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 27,510
