필요한 것
The Logitech Harmony One is a fantastic universal remote. Its well designed case, heft and button placement make it an ideal remote for a complex media setup. While the unit is well sealed against spills if you get something sticky in the buttons it will make it hard to use!
Release the tabs securing the case together by inserting a thin, rigid opening tool near the center of the remote (near the mute and back buttons) and following the gap on the front side of the remote.
Hold the charging contacts, LCD display and front cover together as you remove the backing.
댓글 17개
Great guide! I wish I would have read it first before attempting to disassemble my remote to clean the buttons. Is there any way to repair where the ribbon cable contacts attach the clear plastic film on the face? It separated a little from the film and now the touch screen isn't working for the soft buttons (i.e. Current Activity, Options or Devices, etc.). Thanks!
nuukem : I had the same problem when I cleaned the buttons on my remote. I found a tip that said to gently heat the ribbon with a solder iron or heat gun. (http://www.instructables.com/id/How-to-r...) I used foil on the tip of my iron and made sure it was set before reassembling. Be patient and work slowly. Since the rest of the ribbon should be in place, it should be easy to get the contacts aligned. This worked for me. Hope it helps you. Also, my battery is swollen, so removing it after the cover is off and loosening the screw on the holder makes it easier to remove.
I have an intermittent "0". Would a little alcohol and Q tip on the metallic(?) touch pad fix the problem? I understand this model is no longer available so I want to be very careful. I prefer this model because of the large LCD screen. Thanks for the great write-up!
Sure but use at least 95%+ IPA (Isopropyl Alcohol) so no residue is left on the contacts.
mike -
