주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Logitech M Series Mouse 수리는 저희 서비스 설명서를 사용하십시오.
  1. Logitech M235 Teardown, Logitech M235 Teardown: 1 단계, 이미지 1/1
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: 2 단계, 이미지 1/2 Logitech M235 Teardown: 2 단계, 이미지 2/2
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: 3 단계, 이미지 1/1
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: 4 단계, 이미지 1/1
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: 5 단계, 이미지 1/1
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: 6 단계, 이미지 1/1
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: 7 단계, 이미지 1/1
    • Done!
Daniel
회원 가입일: 11/27/16
225 평판
안내서 1개 작성함
4Bits Repairs 4Bits Repairs 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 8개
Great work. Hope to see some more of your work
Mustafa karu - 답글
thank you..this helped me a looot
Sharnav Kundu - 답글
My M325 has NO SCREWS!!! Now what???
christcansaveyou - 답글
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - 답글
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Robert Reite - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 84
전체 시간: 21,214
