소개
Teardown of the Logitech S120 Slim Mini Stereo Speakers.
필요한 것
Desktop Computer Speakers
Weight: 1lb
Height: 6.22 in
Width: 2.67 in
Depth: 2.51 in
Power: 2.2W (RMS)
RCA and 3.5mm jack inputs
Remove the speaker grills using a thin, flat object such as a flathead screwdriver.
Insert the tool where the grill connects to the chassis just above the logitech logo.
Pry upwards until the grill releases
Insert the flathead screwdriver in the seam between the speaker chassis.
Use force to jam the flathead screwdriver into the chassis.
Drag the screwdriver around the chassis until the two sides separate.
Using a phillips head screwdriver, remove the screws holding the PCB, transformer, and speakers to the chassis.
Pull the PCB, transformer, and speakers from the chassis.
This isnt what mine looks like at all. Granted, the step down transformer and affiliated components are on the other speakers board, but that just takes care of wattage input.
Mine litteraly consists of 3 capacitors, 1 SC1863 IC chip, 1 led, 1 potentiometer, and 1 headphone jack. It also has power and speaker connections, but I dont consider those components. That's it.
The driver board contains several components
Stereo Amplifier: TEA2025B
5mm LED power indicator
Potentiometer and on/off switch
Decoupling, bypass, and AC coupling capcaitors
댓글 3개
I took mine apart, only the Speaker that contains the On/Off Volume— Potentiometer. That Speaker fell off my table and hit the floor landing on the Volume control knob, since then the Speakers do not work unless I insert something to keep pressure on the Volume Control’s shaft. Is it possible to obtain and replace the potentiometer/On/Off Switch…?
Yeah. Same here. I was blown away of the fact that there are no trasistors. Zero. None.
There is one IC chip, SC1863. But I cant find info on it.
Actually I just want to use it as a portable usb powered guitar amp. But I cant get my head around no transistors in it. Weird, huh?
