주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Logitech V220 - Cordless Optical Mouse 수리는 저희 서비스 설명서를 사용하십시오.
  1. Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 1 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 1 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 1 단계, 이미지 3/3
    • Wash your hands before replacing the battery to prevent debris getting into the mouse and damaging its internal components.
    • Orient the mouse so you are viewing its base.
    • Using your fingers, gently remove the USB wireless receiver by sliding it towards you.
    • USB removal will result in the power switch to be in its ON position.
    • With your fingertip, engage the power switch to its OFF position to ensure the mouse is not powered.
  2. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 2 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 2 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 2 단계, 이미지 3/3
    • Locate the four mouse pads.
    • Use the rectangular end of the metal spudger to get underneath each mouse pad, pry them up, and peel them off.
  3. Logitech V220 - Cordless Optical Mouse Teardown, Unscrewing the Mouse Housing Screws: 3 단계, 이미지 1/1
    • Locate the four #0 Phillips screws where the mouse pads previously were.
    • Unscrew the four #0 Phillips screws with the Phillips #0 screwdriver.
  4. Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: 4 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: 4 단계, 이미지 2/2
    • Once the housing screws are fully removed, slowly (and carefully) separate the top and bottom halves of the housing.
    • Rapid separation of the housing halves may result in damaging the power cables (red and black wires) and molex (white plug).
  5. Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: 5 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: 5 단계, 이미지 2/2
    • Gently set the mouse halves down on a flat surface.
    • Secure the base half with one hand.
    • With thumb and forefinger, grab the end of the molex and pull it away from you until the molex is unplugged.
  6. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 6 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 6 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 6 단계, 이미지 3/3
    • Locate the one, scroll wheel, #0 Phillips screw near the very front edge of the mouse.
    • Turn the mouse 90 degrees clockwise.
    • While supporting the rear of the mouse base, unscrew the #0 Phillips scroll wheel screw.
    • Once the scroll wheel screw is fully removed, manually extract the scroll wheel and spring assembly.
  7. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: 7 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: 7 단계, 이미지 2/2
    • Locate the scroll wheel spring.
    • Use the tweezers to gently remove the spring by slowly tugging the spring away from the scroll wheel assembly.
  8. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 8 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 8 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 8 단계, 이미지 3/3
    • Locate and remove the circuit board screw.
    • Grip the edges of the circuit board.
    • Manually remove the circuit board from the base of the mold housing.
  9. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons Screw: 9 단계, 이미지 1/1
    • Locate and remove the #0 Phillips screw in the middle of the mouse.
  10. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 10 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 10 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 10 단계, 이미지 3/3
    • Flip over the top half of the mouse housing so you are viewing underneath it.
    • Locate the mouse button hooks.
    • Rotate the housing 180 degrees clockwise.
    • Using the spudger, firmly push down on each mouse button until the mouse button is released from the hook.
    • Viewing the front of the mouse, the left and right mouse buttons should be detached from the housing.
  11. Logitech V220 - Cordless Optical Mouse Teardown: 11 단계, 이미지 1/1
    • Hold the housing so you are looking down the battery slot.
    • Place the flat end of the spudger between the mouse buttons and the housing.
    • Pry off the mouse buttons.
Tyler Price
회원 가입일: 04/07/14
1,038 평판
안내서 6개 작성하였습니다
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 회원
CPSU-FORTE-S14S6G2
5 회원들
안내서 20개 작성하였습니다
댓글 한 개
Tyler - Very good work on this and your other work on this mouse. I appreciate your attention to detail. I wonder if you are the T. Price who used to go to MacDonalds in U/A in 1995? Thanks again so much for your professional work!
Rik Lesel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 59
전체 시간: 4,830
