주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
추천 문서
  1. MacBook A1150 Teardown, Battery: 1 단계, 이미지 1/1
    • Shut down the computer and disconnect the power cord and any other cables connected to the computer
    • Place the computer face down
    • Slide both battery latches away and lift the battery out
  2. MacBook A1150 Teardown, Memory: 2 단계, 이미지 1/3 MacBook A1150 Teardown, Memory: 2 단계, 이미지 2/3 MacBook A1150 Teardown, Memory: 2 단계, 이미지 3/3
    • Remove the three screws from the memory door
    • Remove the door as shown
    • Remove the memory cards by carefully spreading the tabs away from the card
    • Pull the card straight back and out
  3. MacBook A1150 Teardown, Top Case: 3 단계, 이미지 1/3 MacBook A1150 Teardown, Top Case: 3 단계, 이미지 2/3 MacBook A1150 Teardown, Top Case: 3 단계, 이미지 3/3
    • Remove the six screws on the bottom and the two in the battery bay
    • Remove the four screws from the side and two on the back
  4. MacBook A1150 Teardown, Top Case Cont.: 4 단계, 이미지 1/3 MacBook A1150 Teardown, Top Case Cont.: 4 단계, 이미지 2/3 MacBook A1150 Teardown, Top Case Cont.: 4 단계, 이미지 3/3
    • Open the display slightly past 90 degrees and use a spudger to loosen the top case
    • A snapping noise is normal
    • Do not lift the top case once it is free
    • Slowly lift the top case until you can see the ribbon cable, carefully unplug then lift the top case off
  5. MacBook A1150 Teardown: 5 단계, 이미지 1/2 MacBook A1150 Teardown: 5 단계, 이미지 2/2
    • Remove two antenna connectors. Lift straight up
    • Remove one screw and bracket. The card should rise up slightly
    • Pull the card straight out
첨부 문서
Luke
회원 가입일: 09/27/17
1,613 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,221
