해당 분해도에 사용된 도구
동영상 개요
소개
Apple used its Worldwide Developers Conference to yet again debut a new MacBook Air model. Join us as we see what 12 months of vintaging has done for the 13" variety of Cupertino's prized ultra-slim laptop.
Can't get enough iFixit? Stay up to date with all of the cool happenings by following our Insta-Tweet-Book!
A day after its announcement, the newest 13" MacBook Air is in our hands. Let's see what it's got.
4th generation Intel Core i5 processor with Intel HD graphics 5000
128 GB flash storage (configurable to 512 GB)
4 GB LPDDR3 RAM, configurable (but not upgradable) to 8 GB
13.3" 1440x900 pixel display (~128 ppi)
802.11ac Wi-Fi connectivity
Dual microphones
Externally, the 2013 MacBook Air is nearly identical to its predecessor, including the model number (A1466).
The right side ports haven't changed a bit, with the new MacBook sporting the same lineup of SD card reader, USB 3.0, and Thunderbolt port.
A 180° rotation gives us a glimpse of the only noticeable change to the outer case: two ports for the dual microphones along the left side.
We heard all the new stuff was inside the computer, so we grabbed our unfortunately necessary Pentalobe bit to open 'er up.
As we've come to expect by now, MacBooks of all shape and size are easy to open with the appropriate tools at hand.
We can spot the differences between the 2012 (left) and 2013 (right) MacBook Airs, but can you? Let's see if you see what we see.
Smaller SSD module
Updated AirPort card
No separate platform controller hub
New heat sink clamp
Opposite-facing speaker cable connector
We could nitpick the differences between the two models all day, but we'd rather get back to disassembling the new guy.
When we want to fast-forward through battery removal we go double time on our screw removal.
The 7.6 V, 7150 mAh battery inside this year's Air is an upgrade from the 2012's 7.3 V, 6700 mAh power source and contributes to the claimed 12-hour battery life.
Increased capacity isn't the only addition to the new battery—important information is now printed in
ChineseKorean as well as English.
Thanks, fixed.
I would give my right arm to be ambidextrous!
I have a question - The 2013 model's battery looks to be the same size and shape of the 2011, 2012 (A1369) models' - Is it possible to install a 2013 model's battery in a 2011 model (for example) in order to get that coveted 12 hour battery life? Or is it more complicated than a simple swap?
I was replacing my wife's keyboard, and I thought I had stripped a screw on this step, but upon further examination I discovered these battery screws were actually 6-sided! So I used T6 and the screw that I had thought was stripped came right out! *phew*
Also perhaps it's assumed here, but I would mention the requirement to pull on the connection tab on the upper left section prior to pulling off the battery.
In order to achieve flash storage that's "up to 45 percent faster" than the previous model, Apple switched from SATA to PCIe, and turned to its best pal in the industry: Samsung.
In this case we find:
Samsung S4LN053X01-8030 (ARM) flash controller
8 x Samsung K9LDGY8SIC-XCK0 16 GB flash storage
Samsung K4P2G324ED 512 MB RAM (the same RAM used in the Raspberry Pi)
Next out is the totally redesigned AirPort card, providing 802.11ac Wi-Fi connectivity.
At the heart of the card we find a Broadcom BCM4360, which enables operation on the 5 GHz band at speeds up to 1.3 Gbps and communication via Bluetooth 4.0.
Also on the board is a Skyworks SE5516 dual-band 802.11 a/b/g/n/ac WLAN front-end module.
Dear team iFixit. Please, for the love of god, do indeed go ahead and try your darndest to install this in the 2012 model, I will most certainly buy an 802.11ac AirPort-card from you, as well as any potential "kit" or otherwise to install it, if you end up bringing out such a product! And I know at least 5 other people who will as well!
Yes Please!!! I would Pre=Order the card from you today if it's possible!
tilhas -
Add Me to the list.
I personally ordered an 802.11AC card using my Authorized repair account and stuck it in my 2011 macbook air. And although the card was a bit longer, it still fit in. Unfortunately I also had to reroute some cables since they weren't quite long enough to reach. But in the end I was successful. I now have an 802.11AC card working perfectly fine in my laptop. I'm getting good signal, and System info reports the full AC capabilities of my card. Also keep in mind that since the card is longer you won't be able to secure it down with a screw, you'd likely need to use some sort of ESD tape.
Is it hard to reroute the antennas ofter securing the new ac card down on older systems?
Jordan -
Oh God I'm foaming at the mouth over the idea of putting an 802.11AC card into my 2013 retina MacBook Pro....I just hope it isn't an insane install job as I generally don't like to open up my electronics tell they are out of warranty, besides messing with my new $2300 MacBook? Ill need a drink or two after that! I've done optibay, RAM, Hard Drive and even some more advanced stuff on the 13 and 15" unibody MBP's but sounds risky. Still 802.11ac is very nice, even though its not out yet I'd like to have it to make it more future proof! Keep us updated on if its possible with the rMBP!
Has anyone tried to connect a external wifi antenna? The wifi antenna connector is broken by the previous user. I am looking for 2 wifi antenna. What I want to do is to attach the wifi antenna outside the MacBook air to improve the reception.
Does any one know where to buy the antenna (only antenna, not with isight camera.....etc) ? Is Ipad antenna compatible or any other apple product?
What's that sound? Oh, it's just the MacBook Air's stereo speakers.
Other than the aforementioned change in the direction of one of the speaker cables, these appear to be the same speakers found in last year's model.
Some computer and smartphone manufacturers like to emphasize an industry partner's audio systems in their marketing. Apple is not one of those companies, simply listing the noisemakers in the MacBook Air as "stereo speakers."
The I/O board in the MacBook Air is mostly unchanged from last year, except that it no longer has a socket for the iSight cable.
We find a Cirrus chip marked 4208-CRZ next to the headphone jack. This appears to be a two-channel version of the CS4207 low power HD audio codec with headphone amp.
Goodnight logic board.
Goodnight heat sink.
The new heat sink design allows it to cover both chips, but Apple only put thermal compound on the CPU.
We won't complain too much though, as the old design left the PCH out in the hot with only the lower case as a heat sink.
Is there any other material than the thermal paste on the CPU like wax or plastic seal that could hinder thermal transfer? The core looks blackish to me... If there is, is it something removable?
It's only thermal paste on the CPU core; in the top-down shot in step 12, the black is a reflection of our camera :).
could the logic board be installed on a 2012 model?
Does the platform controller need thermal paste?
Let's take a closer look at the logic board:
1.3GHz (with Turbo Boost up to 2.6 GHz) dual-core Intel Core i5 processor, with integrated Intel HD graphics 5000
Intel platform controller hub (unmarked)
Intel DSL3510L Thunderbolt controller
Genesis Logic GL3219 USB 3.1 Gen 1 hub controller
Linear Technology LT3957 inverting controller
The orange chip looks like Intel's new eDRAM module for its Iris Pro graphics.
No, that is correctly labelled as the platform controller hub. Before Haswell it was a separate chip package but is now situated on the same package as the CPU/GPU. The 2013 MacBook Air has Intel HD 5000 graphics, not Iris (5100) or Iris Pro (5200).
Emyr -
Error in name Thunderbolt controller. In Air 2013 is the same like Air 2012 (DSL3510L):
On the flip-side we find:
Elpida F8132A1MC LPDDR3 RAM 4 x 1 GB modules for 4 GB total
Broadcom BCM15700A2
Hynix H5TC4G63AFR 8 Gb synchronous DRAM
MXIC MX25L6406E 64 Mb serial flash
Texas Instruments TPS51980A synchronous buck controller
980 YFC LM4FS1BH
What is the Hynix H5TC4G63AFR 4 Gb synchronous DRAM for? That's 512MiB that's not part of main memory, and I don't see a chip that's analogous to it on earlier models.
Can Haswell's iGPU use RAM that's dedicated to it rather than share the main system RAM?
It could be related to the iGPU, but definitely not as traditional GPU memory. From Anandtech :-"To allow the entire platform to go to sleep while the display is still active, Intel recommends Panel Self Refresh (PSR) to be implemented in Haswell Ultrabooks. The idea behind PSR is to put DRAM on the panel itself to store the frame buffer. In the event of a static display (e.g. staring at a Word document, looking at your desktop), the GPU frame buffer is copied to the panel’s DRAM, and the GPU itself is shut off instead of having to drive meaningless content updates to the display 60 times per second. With PSR, the SoC can go into its deepest sleep state (C10)."Could this power-saving frame buffer be placed on the MBA motherboard instead of the LCD panel itself, contributing to the 2013 MBA's extended battery life?Apparently this isn't the case, so what's the mystery RAM used for then? Is it related to the BCM15700A2?
Emyr -
Can ifixit kindly take the display apart too? We will love to find out how many antenna the 802.11ac is connected to.
Kelvin Nye - 답글
Seconded!
Also, to anyone reading this, what are your thoughts on the overall upgrade? I was hoping for retina so I can't decide if now is a good time to upgrade.
Brian -
@burke102, wait for Intel Skymont 10nm. That's when we'll see 10nm chips and probably 4-core Macbook Air and 6 cores with regular sized laptops.
Single threaded performance will be improved too
As in most other unibody MacBooks, the Air's trackpad is held to the upper case with six tiny Phillips screws and comes out without much hassle.
In addition to a plethora of connectors, we find the following chips on the trackpad board:
STMicroelectronics STM32F103VB microcontroller
MXIC MX25L2006E 2 Mb serial flash
Broadcom BCM5976A0KUB2G trackpad controller
Finally, we free the display assembly from the upper case by removing the Phillips screws that secure the two hinges.
For whatever reason, when I went to take out the 6 screws for the trackpad, the top 3 screws on each side stripped! Something held those a little closer together perhaps?
MacBook Air 13" Mid 2013 Repairability Score: 4 out of 10 (10 is easiest to repair).
Once you manage to take off the bottom cover, all the parts are pretty easily replaceable.
Proprietary screws on the case require the right screwdriver.
All the components—including RAM and SSD—are proprietary.
As with the prior iterations, this MacBook Air's biggest detractor is the lack of upgradeability. The RAM is still soldered to the logic board, and SSDs are not compatible between generations.
댓글 17개
The guide is wrong in saying the GPU is segregated in the old model and right beside the processor in the new one, that's not the GPU. The GPU is part of the CPU die, that's why it's long like that. I think the segregated chip in the old one and the adjacent chip in the new one is the Platform Controller.
And they even said so in the older guide, just the new one is wrong.
Updated. We suspect this new chip (next to the CPU) is the Platform Controller Hub.
Would you recommend (if you have the proper tools and know-how) taking apart a new Air and putting thermal compound on the second portion of the cpu?
I've seen a lot of tests about what the best way to apply thermal paste for most heat transfer-ability, and it seems like the less-is-better model has the best effect. I've noticed in repairing a lot of Apple laptops, that they just gob the thermal compound on to the point where it's overflowing out the sides of the processor. So I'd probably redo the thermal compound anyway, might as well put some on the rest of the processor. That would only help right?
It would help thermal transfer, but it's possible it's not necessary. I don't see what it would hurt, but I'd suggest holding off until you see what the thermal characteristics of your system are out of the box.
since you took off the heatsink a reapply with mx4 would be good in future, temps before temps after etc, evaluate factory tim performance ? but since no ivy and haswell factory IHS & Tim lga based issues, core temps should be within a 1-3degs of each other with direct heat sink to cpu die contact, and not varying by 10 degrees like on the lga version when OC'ed hard.
Better to repaste with MX2 rather than MX4. Longevity is important here since the difficulty of taking the laptop apart is high. MX2 is rated for 8 years of durability.
Well done, Gwendolyn! You have an awesome voice/presence for teardowns. Look forward to the next one.
I have a1466 ,2013 and my logic board totally damage ,and I order board from ebay new board wrongly they send me 2012 board , can this board fit on my 2013
I have a1466 mid 2013. I want to purchase a whole led assembly replacement. Can I use assemblies from 2010-2014. Or do I need to purchase the same year I have. Thanks
Jason Dutt - 답글
I have a1466 mid 2013. I want to purchase a lcd assembly. Do I need to buy the exact year. Or can I get a range of years. 2010-2015? Thanks
Jason Dutt - 답글
I have a1466 mid 2013 that had water damage. After replacing the battery the 1466 has come back to life however, the airport card seems to be dead now having spent a hundred dollars I'd hate to spend much more to make this machine functional again. Does anyone have any suggestions.. If not repairing then a reliable place to purchase an airport card. Thanks, Daniel Butts
The keyboard backlight has stopped working in mine, where is the plug? i suspect that it has jumped out.
-Viktor
