주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Mouse 수리는 저희 서비스 설명서를 사용하십시오.
  1. Mechanical Mouse Teardown, Mechanical Mouse Teardown: 1 단계, 이미지 1/3 Mechanical Mouse Teardown, Mechanical Mouse Teardown: 1 단계, 이미지 2/3 Mechanical Mouse Teardown, Mechanical Mouse Teardown: 1 단계, 이미지 3/3
    • Rotate mouse over and locate Trackball cover
    • Using index fingers and thumb, rotate counter-clockwise
  2. Mechanical Mouse Teardown: 2 단계, 이미지 1/3 Mechanical Mouse Teardown: 2 단계, 이미지 2/3 Mechanical Mouse Teardown: 2 단계, 이미지 3/3
    • After the Trackball cover has been rotated, pry the lid off using fingernails.
    • Remove Trackball cover and place to the side.
    • Angle mouse to eject Trackball from the casing.
  3. Mechanical Mouse Teardown: 3 단계, 이미지 1/3 Mechanical Mouse Teardown: 3 단계, 이미지 2/3 Mechanical Mouse Teardown: 3 단계, 이미지 3/3
    • Using a Phillips head screwdriver, locate screw hole and unscrew the screw inside.
    • Lift the two cases apart and place screw to the side.
  4. Mechanical Mouse Teardown: 4 단계, 이미지 1/3 Mechanical Mouse Teardown: 4 단계, 이미지 2/3 Mechanical Mouse Teardown: 4 단계, 이미지 3/3
    • Remove the wire from the plastic casing near the top of the mouse.
    • Lift up to remove the PCB which is attached to the mouse.
    • Place case to the side.
  5. Mechanical Mouse Teardown: 5 단계, 이미지 1/3 Mechanical Mouse Teardown: 5 단계, 이미지 2/3 Mechanical Mouse Teardown: 5 단계, 이미지 3/3
    • Locate where the wire is connected to the PCB via the white connection.
    • Pry the connections apart and place the cable to the side.
Kevin Gingrich
회원 가입일: 10/06/11
180 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 회원
CPSU-MANESS-F11S20G28
4 회원들
안내서 15개 작성하였습니다
댓글 2개
Wow! Someone really worked hard on this guide. Kudos sir.
Tushar Varshney - 답글
Yes sir I won't know everything about the machine
mubarak wad gab tagel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 65
전체 시간: 5,473
