주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Mele F10 수리는 저희 서비스 설명서를 사용하십시오.
  1. Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 1 단계, 이미지 1/3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 1 단계, 이미지 2/3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 1 단계, 이미지 3/3
    • 2.4GHz wireless frequency
    • Max. control range: 30 meters
    • IR remote range: 10 meters
    • Built-in 500mAh battery
  2. Mele F10 - USB Remote Teardown: 2 단계, 이미지 1/2 Mele F10 - USB Remote Teardown: 2 단계, 이미지 2/2
    • There is no screws. I have opened remote only by hands by bendig edges
  3. Mele F10 - USB Remote Teardown: 3 단계, 이미지 1/3 Mele F10 - USB Remote Teardown: 3 단계, 이미지 2/3 Mele F10 - USB Remote Teardown: 3 단계, 이미지 3/3
    • OK! let see what parts we have inside
    • nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
    • ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
    • IR TX diode
  4. Mele F10 - USB Remote Teardown: 4 단계, 이미지 1/3 Mele F10 - USB Remote Teardown: 4 단계, 이미지 2/3 Mele F10 - USB Remote Teardown: 4 단계, 이미지 3/3
    • More parts
    • JTAG ?
    • Mini-USB port - as far as I know can be used only to charging
    • 500mAh battery
  5. Mele F10 - USB Remote Teardown: 5 단계, 이미지 1/3 Mele F10 - USB Remote Teardown: 5 단계, 이미지 2/3 Mele F10 - USB Remote Teardown: 5 단계, 이미지 3/3
    • USB Receiver
    • nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Adam
회원 가입일: 10/12/11
128 평판
안내서 1개 작성함
댓글 12개
Super! Thank you
nisko84 - 답글
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
Jose Manuel Peinado Navarro - 답글
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
http://forum.mele.cn/showthread.php?tid=...
drdedus - 답글
Confirm not work with Panasonic TV
Aurel Enache -
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Amine Elsemine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 12,452
