2.4GHz wireless frequency
Max. control range: 30 meters
IR remote range: 10 meters
Built-in 500mAh battery
OK! let see what parts we have inside
nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
IR TX diode
첨부 문서
댓글 9개
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
Confirm not work with Panasonic TV
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
