필요한 것
동영상 개요
- To the extent that screws are used, they are all standard Torx fasteners.
- All repairs require first removing the display assembly—which is stubbornly glued in place, expensive, and prone to shattering.
- The battery is also firmly glued in place, requiring tons of heat and prying or solvents to remove.
- The RAM, SSD and CPU are all soldered to the motherboard. Replacing any of those components requires a full motherboard replacement.
최종 결론
수리 용이성 점수
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter-background.png)
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter.png)
수리 용이성 10점 중 1점
(10은 가장 쉬운 수리를 뜻합니다)
댓글 16개
that is disappointing. Had small camera issue and just received another device in Microsoft store as warranty case
Yakauleu Aliaksandr - 답글
lol this video is disappointing for sure
Tyler Salazar -
Hi, What is the bluetooth module on surfece pro 7?
John Ostrowski - 답글
It uses an Intel AX201 WiFi chipset, and the bluetooth module built into that.
Chris N -
I’m looking for a replacement touch screen connector for the Surface Pro 7 but i can only find the older model for the pro4 and pro5, could anyone point me in the right direction
James B - 답글
