주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
Open and disassemble the power pack for repair purposes. More details:
https://www.facebook.com/notes/larry-che...
해당 분해도는 수리 안내서가 아닙니다. Mophie PowerStation 5X 수리는 저희 서비스 설명서를 사용하십시오.
  1. The device. The device. The device.
    • The device.
  2. Open the device using a flat head screwdriver and pry the lid up from the middle carefully. Use a metal spudger along the side to open the lid.
    • Open the device using a flat head screwdriver and pry the lid up from the middle carefully.
    • Use a metal spudger along the side to open the lid.
    • Don't push inside too much.
    • This will damage the metal case.
    • The lid is glued to the plastic in the front.
  3. Disconnect the battery pack.
    • Disconnect the battery pack.
    • If you're having problems with the device, disconnect the battery and then reconnect it. That solved the no output problem for me.
  4. Photos of interior. Battery is lightly glued. Battery is lightly glued.
    • Photos of interior.
    • Battery is lightly glued.
  5. More images More images More images
    • More images
  6. More photos More photos More photos
    • More photos
  7. More images More images More images
    • More images
  8. Power and current measurements. Red light is 2A load, green is 1A load. Max. power draw of Galaxy Note5 connected to fastcharge port is 1.62A. Charge current measured at 5V and 9V. Charge current measured at 5V and 9V.
    • Power and current measurements. Red light is 2A load, green is 1A load. Max. power draw of Galaxy Note5 connected to fastcharge port is 1.62A.
    • Charge current measured at 5V and 9V.
  9. simultaneous input and output supported. simultaneous input and output supported. simultaneous input and output supported.
    • simultaneous input and output supported.
  10. ratings
    • ratings
Larry Chen
회원 가입일: 2013년 04월 22일
904 평판
안내서 5개 작성하였습니다
댓글 3개
Hey! Could you give the measurements on each of those battery units?
justin - 답글
Unfortunately I don't have this thing anymore, but if you look up the official specs, then go by the proportions on-screen, you can probably get a decent idea.
Larry Chen -
Hi I see it's 3 years later but I was wondering if you remember how you disconnected the battery? My pack is fully charged and I'm a little worried on how to disconnect.
Newbie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 64
전체 시간: 9,116
