주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Mophie PowerStation 5X 수리는 저희 서비스 설명서를 사용하십시오.
  1. Mophie PowerStation 5X Teardown, Mophie PowerStation 5X Teardown: 1 단계, 이미지 1/3 Mophie PowerStation 5X Teardown, Mophie PowerStation 5X Teardown: 1 단계, 이미지 2/3 Mophie PowerStation 5X Teardown, Mophie PowerStation 5X Teardown: 1 단계, 이미지 3/3
    • The device.
  2. Mophie PowerStation 5X Teardown: 2 단계, 이미지 1/2 Mophie PowerStation 5X Teardown: 2 단계, 이미지 2/2
    • Open the device using a flat head screwdriver and pry the lid up from the middle carefully.
    • Use a metal spudger along the side to open the lid.
    • Don't push inside too much.
    • This will damage the metal case.
    • The lid is glued to the plastic in the front.
    Batteries are also glued to the lid. You will need to use something blunt like a butter knife to separate the glue from the battery to prevent damage before opening the case too far.
    jlhrstv - 답글
  3. Mophie PowerStation 5X Teardown: 3 단계, 이미지 1/1
    • Disconnect the battery pack.
    • If you're having problems with the device, disconnect the battery and then reconnect it. That solved the no output problem for me.
  4. Mophie PowerStation 5X Teardown: 4 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 4 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 4 단계, 이미지 3/3
    • Photos of interior.
    • Battery is lightly glued.
  5. Mophie PowerStation 5X Teardown: 5 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 5 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 5 단계, 이미지 3/3
    • More images
  6. Mophie PowerStation 5X Teardown: 6 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 6 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 6 단계, 이미지 3/3
    • More photos
  7. Mophie PowerStation 5X Teardown: 7 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 7 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 7 단계, 이미지 3/3
    • More images
  8. Mophie PowerStation 5X Teardown: 8 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 8 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 8 단계, 이미지 3/3
    • Power and current measurements. Red light is 2A load, green is 1A load. Max. power draw of Galaxy Note5 connected to fastcharge port is 1.62A.
    • Charge current measured at 5V and 9V.
  9. Mophie PowerStation 5X Teardown: 9 단계, 이미지 1/3 Mophie PowerStation 5X Teardown: 9 단계, 이미지 2/3 Mophie PowerStation 5X Teardown: 9 단계, 이미지 3/3
    • simultaneous input and output supported.
  10. Mophie PowerStation 5X Teardown: 10 단계, 이미지 1/1
    • ratings
Larry Chen
회원 가입일: 04/22/13
913 평판
안내서 5개 작성하였습니다
댓글 3개
Hey! Could you give the measurements on each of those battery units?
justin - 답글
Unfortunately I don't have this thing anymore, but if you look up the official specs, then go by the proportions on-screen, you can probably get a decent idea.
Larry Chen -
Hi I see it's 3 years later but I was wondering if you remember how you disconnected the battery? My pack is fully charged and I'm a little worried on how to disconnect.
Newbie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 42
전체 시간: 10,754
