필요한 것
This is a front view of the Motorola 120e that I will be tearing down. You will obviously want to turn off the device before proceeding.
Now you can remove the battery cover by pressing the black button down and lifting up. You can then remove the battery by pressing it forward and lifting up on it. Thankfully, there is no adhesive to be found.
Now with the battery removed, you can unscrew the 6 T5 torx screws. 2 of them are at the top of the phone, and 4 more are in the battery bay. Once those are removed, You can lift the back panel off of the phone.
On the plastic back panel, there is the non-removable antenna, vibrate motor, and speaker. You can use a spudger to remove these.
After removing the back, you should now see the board, with the front panel on the other side.
The front panel can be lifted off the board, and the rubber buttons can be removed from the front frame.
You can remove the screen by unclipping the 4 clips around the edge of the board and carefully lifting the screen off.
Here is all of the parts laid out. To re-assemble, follow the guide in reverse order.
