주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Motorola C350 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola C350 Teardown, Rear case freeing: 1 단계, 이미지 1/2 Motorola C350 Teardown, Rear case freeing: 1 단계, 이미지 2/2
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Teardown, Removing battery: 2 단계, 이미지 1/1
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Teardown, Separating the front case: 3 단계, 이미지 1/2 Motorola C350 Teardown, Separating the front case: 3 단계, 이미지 2/2
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Teardown, Keyboard: 4 단계, 이미지 1/1
    • Use your thumb to gently peel the keyboard off the front case.
    • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
  5. Motorola C350 Teardown, Logic Board: 5 단계, 이미지 1/2 Motorola C350 Teardown, Logic Board: 5 단계, 이미지 2/2
    • Remove the 4 T6 Torx screws
  6. Motorola C350 Teardown: 6 단계, 이미지 1/2 Motorola C350 Teardown: 6 단계, 이미지 2/2
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  7. Motorola C350 Teardown: 7 단계, 이미지 1/1
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  8. Motorola C350 Teardown, Ear Speaker: 8 단계, 이미지 1/2 Motorola C350 Teardown, Ear Speaker: 8 단계, 이미지 2/2
    • Remove the four T6 Torx Screws
  9. Motorola C350 Teardown: 9 단계, 이미지 1/1
    • Use a metal spudger togently free the screen/ear speaker metal case.
  10. Motorola C350 Teardown: 10 단계, 이미지 1/1
    • Slowly peel the ear speaker off the case.
    • Be really careful about the small plastic pin which can be easily lost.
  11. Motorola C350 Teardown, Display: 11 단계, 이미지 1/1
    • Remove the two small metal clips keeping the cables safe.
  12. Motorola C350 Teardown: 12 단계, 이미지 1/1
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
  13. Motorola C350 Teardown: 13 단계, 이미지 1/1
    • Use a plastic spudger to release the disconnected screen.
  14. Motorola C350 Teardown, Microphone: 14 단계, 이미지 1/1
    • Use a plastic spudger to unclip the mic.
  15. Motorola C350 Teardown, Upper Speaker: 15 단계, 이미지 1/1
    • The upper speaker is kept in place by a metal plate.
    • Use a metal spudger to free the 3 clips on the back side
  16. Motorola C350 Teardown: 16 단계, 이미지 1/1
    • Insert your metal spudger to remove the metal plate and free the upper speaker.
  17. Motorola C350 Teardown, Parts overview: 17 단계, 이미지 1/1
    • Here you can see all the parts composing the Motorola C350.
Vincent Monteil
회원 가입일: 07/06/13
6,975 평판
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,708
