해당 분해도에 사용된 도구
해당 분해도는 수리 안내서가 아닙니다. Motorola California Mobile Phone 수리는 저희 서비스 설명서를 사용하십시오.
  1. Remove the battery by sliding it down the rails to which it is connected.
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Find a flat head or Phillips head screwdriver.
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  5. Locate and unplug the black component of the antenna from the motherboard.
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  6. Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  7. Lift the motherboard out of its location in the front casing.
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
Andrew Lam
회원 가입일: 2012년 04월 17일
28 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 회원
CPSU-REGAN-S12S9G46
5 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 4
전체 시간: 7,080
