주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Motorola Defy 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Defy Teardown, Motorola Defy Teardown: 1 단계, 이미지 1/1
    • Power down the phone
  2. Motorola Defy Teardown: 2 단계, 이미지 1/2 Motorola Defy Teardown: 2 단계, 이미지 2/2
    • On the back there is a slider that locks the back cover on slide this over to unlock it.
  3. Motorola Defy Teardown: 3 단계, 이미지 1/1
    • Remove the battery and sim card as well as the micro sd if one.
  4. Motorola Defy Teardown: 4 단계, 이미지 1/1
    • Remove the two torx screws in each corner.
  5. Motorola Defy Teardown: 5 단계, 이미지 1/2 Motorola Defy Teardown: 5 단계, 이미지 2/2
    • Remove the 3 torx screws on both sides.
    • Now remove one more torx screw on the bottom.
  6. Motorola Defy Teardown: 6 단계, 이미지 1/1
    • Use the pry tool and insert in between the black and white plastic. Slide across all sides to unlock the clips holding it together.
  7. Motorola Defy Teardown: 7 단계, 이미지 1/3 Motorola Defy Teardown: 7 단계, 이미지 2/3 Motorola Defy Teardown: 7 단계, 이미지 3/3
    • Remove the the back case (white section) revealing the logic board.
  8. Motorola Defy Teardown: 8 단계, 이미지 1/3 Motorola Defy Teardown: 8 단계, 이미지 2/3 Motorola Defy Teardown: 8 단계, 이미지 3/3
    • Use the pry tool and detach the digitizer cable and LCD cable from the board.
  9. Motorola Defy Teardown: 9 단계, 이미지 1/1
    • Lift the logic board out of the phone revealing the LCD.
  10. Motorola Defy Teardown: 10 단계, 이미지 1/1
    • Use pry tool to gently lift the LCD out of the phone revealing the digitizer.
  11. Motorola Defy Teardown: 11 단계, 이미지 1/1
    • Now all that is left is the digitizer frame holding the digitizer.
    • To remove a broken digitizer heat the front edges of this frame to soften the digitizer adhesive and pry away from the frame.
  12. Motorola Defy Teardown: 12 단계, 이미지 1/1
    • Thats it now just follow these steps in reverse to put your phone back together.
Jared
회원 가입일: 02/14/11
530 평판
안내서 1개 작성함
댓글 5개
Brilliant! Many thanks. Things to watch: the volume rocker and on switch tend to fall out, so secured them to the back with a little bit of masking tape while I reassembled. Helped to slightly lift one end of the motherboard so the case can go around the USB power socket. After that it fits back together with only minor persuasion.
Gareth Dart - 답글
Hi,
my Search "button" stop lightning. The other 3 "buttons" are ok.
Did someone know the reason?
Thank you!
timarzoltan83 - 답글
Thanks for help! Real great Guide.
Daniel - 답글
Help! I bought a t5 torx screwdriver to open my motorola and the screwdriver seems too smal! Wtf? Many dismount video says that this is a t5 model, I don't understand...
Pierre Flq - 답글
can you mark ram on that board ?
demon leaks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 22,255
