주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Motorola Moto G 2nd Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: 1 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: 1 단계, 이미지 2/2
    • Remove back cover. It's easy, no adhesive and no screws.
  2. Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 3/3
    • Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
  3. Motorola Moto G 2nd Generation Teardown: 3 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 3 단계, 이미지 2/2
    • Take away the volume button and power button.
  4. Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 3/3
    • Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
  5. Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 3/3
    • Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
  6. Motorola Moto G 2nd Generation Teardown: 6 단계, 이미지 1/1
    • At that time, remove the battery with SIM & SD card reader assembly together.
  7. Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 3/3
    • Separate battery and SIM & SD card reader assembly.
  8. Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 3/3
    • Release LCD screen connector from motherboard.
  9. Motorola Moto G 2nd Generation Teardown: 9 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 9 단계, 이미지 2/2
    • Release sensor flex connector and front camera connector respectively.
  10. Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 3/3
    • Remove screws on the motherboard and the motherboard can be removed easily.
  11. Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 3/3
    • Remove rear camera.
  12. Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 3/3
    • Remove front camera and sensor cable.
  13. Motorola Moto G 2nd Generation Teardown: 13 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 13 단계, 이미지 2/2
    • Remove earpiece and loudspeaker.
  14. Motorola Moto G 2nd Generation Teardown: 14 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 13개
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
Top View - 답글
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
T-Mobile Huawei Prism U8651T Teardown
Top View -
Can anyone please tell me where I can get the details of the Antenna used for the GSM connection in this phone? Like the drawing or schematic.
Please I really need this as this phone has poor cell reception.
Amol - 답글
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
mihaibanditu - 답글
Where can I get more information about GPS module and its antenna?
Paulo Abner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 53,695
