주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Motorola Moto G 2nd Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: 1 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown, Motorola Moto G 2nd Generation Teardown: 1 단계, 이미지 2/2
    • Remove back cover. It's easy, no adhesive and no screws.
    Also remove the SIM and SDCard!
    Ben Low - 답글
  2. Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 2 단계, 이미지 3/3
    • Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
    "You'd better remember their positions" Can't you make full guides on all your devices?
    Glaceau Clara - 답글
    Hi there! This is a teardown, not a repair guide, check the full manual to see more complete guides, here for instance is a detailed screw removal step.
    Sam Goldheart -
    Just for completion as I made the same mistake today.
    The longer screws are at the top and the bottom (2x4 screws) and the shorter ones (2x3) at the left and right side of the case.
    Took me some time to find out which one goes to which position.
    Sebastian Schwägerl - 답글
  3. Motorola Moto G 2nd Generation Teardown: 3 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 3 단계, 이미지 2/2
    • Take away the volume button and power button.
  4. Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 4 단계, 이미지 3/3
    • Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
    Can u explain little detailed about this step. Unable to release sim connector.
    Goutham Ram - 답글
  5. Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 5 단계, 이미지 3/3
    • Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
  6. Motorola Moto G 2nd Generation Teardown: 6 단계, 이미지 1/1
    • At that time, remove the battery with SIM & SD card reader assembly together.
  7. Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 7 단계, 이미지 3/3
    • Separate battery and SIM & SD card reader assembly.
  8. Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 8 단계, 이미지 3/3
    • Release LCD screen connector from motherboard.
  9. Motorola Moto G 2nd Generation Teardown: 9 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 9 단계, 이미지 2/2
    • Release sensor flex connector and front camera connector respectively.
  10. Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 10 단계, 이미지 3/3
    • Remove screws on the motherboard and the motherboard can be removed easily.
  11. Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 11 단계, 이미지 3/3
    • Remove rear camera.
  12. Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 1/3 Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 2/3 Motorola Moto G 2nd Generation Teardown: 12 단계, 이미지 3/3
    • Remove front camera and sensor cable.
  13. Motorola Moto G 2nd Generation Teardown: 13 단계, 이미지 1/2 Motorola Moto G 2nd Generation Teardown: 13 단계, 이미지 2/2
    • Remove earpiece and loudspeaker.
  14. Motorola Moto G 2nd Generation Teardown: 14 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 13개
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
Top View - 답글
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
T-Mobile Huawei Prism U8651T Teardown
Top View -
Can anyone please tell me where I can get the details of the Antenna used for the GSM connection in this phone? Like the drawing or schematic.
Please I really need this as this phone has poor cell reception.
Amol - 답글
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
mihaibanditu - 답글
Where can I get more information about GPS module and its antenna?
Paulo Abner - 답글
how to remove the external HDD? is there any way to recover data from it after detaching it from the device?
Atul Mohan - 답글
Mala motoG2 chi purn settings pahije
Ashish Barvhan - 답글
Can not remove the LCD?
jm2k7 - 답글
tanto el auricular y el altavoz son iguales si se invierte de posicion
Jorge Laura - 답글
what is issue if the moto g2 phone is heating at corner of near selfie camera when put for charging..
Mak Fighter - 답글
must be reply for my question…
Mak Fighter - 답글
what’s that small ribbon (looks like a thumbs up) coming out in image on step 13. I recently replaced a screen on my motog 2g and found this ribbon lying below battery but didnt know what to do with it. It is not a connector for sure as there are no sockets to connect there. my phone is working fine without my doing anything with that connector. just curious what it is for.
pradeep - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 12
전체 시간: 53,698
