주요 콘텐츠로 건너뛰기
Motorola Moto G3 Teardown
필요한 것
동영상 개요
  1. Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: 1 단계, 이미지 1/2 Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: 1 단계, 이미지 2/2
    • Remove back cover.
    • Moto G3 plastic panel can be easily removed with the fingernails.
  2. Motorola Moto G3 Teardown: 2 단계, 이미지 1/2 Motorola Moto G3 Teardown: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
  3. Motorola Moto G3 Teardown: 3 단계, 이미지 1/2 Motorola Moto G3 Teardown: 3 단계, 이미지 2/2
    • Undo 3 screws by T4 Torx screwdriver.
    • Take away plastic securing part.
  4. Motorola Moto G3 Teardown: 4 단계, 이미지 1/3 Motorola Moto G3 Teardown: 4 단계, 이미지 2/3 Motorola Moto G3 Teardown: 4 단계, 이미지 3/3
    • Heat up the LCD screen for a while.
    • Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
    • There is LCD screen connector on the left side, so be careful to slide guitar picks.
  5. Motorola Moto G3 Teardown: 5 단계, 이미지 1/3 Motorola Moto G3 Teardown: 5 단계, 이미지 2/3 Motorola Moto G3 Teardown: 5 단계, 이미지 3/3
    • Release LCD screen connector firstly.
    • Remove LCD screen.
  6. Motorola Moto G3 Teardown: 6 단계, 이미지 1/3 Motorola Moto G3 Teardown: 6 단계, 이미지 2/3 Motorola Moto G3 Teardown: 6 단계, 이미지 3/3
    • Undo 14 screws by T4 Torx screwdriver
    • Pry up motherboard assembly.
    • Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
  7. Motorola Moto G3 Teardown: 7 단계, 이미지 1/2 Motorola Moto G3 Teardown: 7 단계, 이미지 2/2
    • Release battery flex connector.
    • Separate motherboard assembly from back cover assembly.
  8. Motorola Moto G3 Teardown: 8 단계, 이미지 1/3 Motorola Moto G3 Teardown: 8 단계, 이미지 2/3 Motorola Moto G3 Teardown: 8 단계, 이미지 3/3
    • Undo 3 screws here.
    • Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
  9. Motorola Moto G3 Teardown: 9 단계, 이미지 1/2 Motorola Moto G3 Teardown: 9 단계, 이미지 2/2
    • Remove front-facing camera.
  10. Motorola Moto G3 Teardown: 10 단계, 이미지 1/3 Motorola Moto G3 Teardown: 10 단계, 이미지 2/3 Motorola Moto G3 Teardown: 10 단계, 이미지 3/3
    • Remove rear camera.
  11. Motorola Moto G3 Teardown: 11 단계, 이미지 1/2 Motorola Moto G3 Teardown: 11 단계, 이미지 2/2
    • Remove earpiece.
  12. Motorola Moto G3 Teardown: 12 단계, 이미지 1/2 Motorola Moto G3 Teardown: 12 단계, 이미지 2/2
    • Remove loudspeaker.
  13. Motorola Moto G3 Teardown: 13 단계, 이미지 1/2 Motorola Moto G3 Teardown: 13 단계, 이미지 2/2
    • Here is the motherboard.
  14. Motorola Moto G3 Teardown: 14 단계, 이미지 1/2 Motorola Moto G3 Teardown: 14 단계, 이미지 2/2
    • Use spudger to cut adhesive and pry the battery up.
  15. Motorola Moto G3 Teardown: 15 단계, 이미지 1/3 Motorola Moto G3 Teardown: 15 단계, 이미지 2/3 Motorola Moto G3 Teardown: 15 단계, 이미지 3/3
    • Take away headphone jack.
  16. Motorola Moto G3 Teardown: 16 단계, 이미지 1/1
    • Done
결승점
다른 18명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,493 평판
안내서 378개 작성하였습니다
댓글 7개
Muito bom, parabéns!
Manoel - 답글
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
setsuoleandro - 답글
Wi fi not trun on ..moto g3
Seoni Seoni - 답글
When you heat up the display, do you heat up the entire display or just around the edges? What heat gun/setting should i use? Can i use a blowdryer?
guest - 답글
Thanks. ......................
Biswajit Saha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 41
전체 시간: 23,989
