해당 분해도에 사용된 도구
소개
This guide is for educational purposes and should not be used as a repair guide.
해당 분해도는 수리 안내서가 아닙니다. Moto G4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Place your thumb in the indent located at bottom left corner of the back cover. The cover will pop up and begin to lift.
    • Place your thumb in the indent located at bottom left corner of the back cover.
    • The cover will pop up and begin to lift.
    • Continue to slide your fingers up the sides to remove the back cover.
  2. Using tweezers, remove the gray plastic surrounding the camera lens. There will be a lot of glue and you may have to pull hard on the plastic piece.
    • Using tweezers, remove the gray plastic surrounding the camera lens.
    • There will be a lot of glue and you may have to pull hard on the plastic piece.
  3. With tweezers, slide under all sides of the lens to loosen it. Pulls the lens towards you to remove the lens.
    • With tweezers, slide under all sides of the lens to loosen it.
    • Pulls the lens towards you to remove the lens.
    • There will be glue under the lens. You may have to pull hard to remove the lens.
    • Do not pull too hard on the lens. Pulling hard on it can result in breaking the lens.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel. Keep the screws on a magnetic board or strip to not lose any of them.
    • Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel.
    • Keep the screws on a magnetic board or strip to not lose any of them.
    • After all the screws are removed from the back panel, lift the back panel off.
  6. Using the tweezers, unhook the twisted red and black wire from under the black plastic pieces that are holding it down. Using the tweezers, disconnect the wire from its connective port.
    • Using the tweezers, unhook the twisted red and black wire from under the black plastic pieces that are holding it down.
    • Using the tweezers, disconnect the wire from its connective port.
    • Use the spudger to lift the battery out.
    • The battery is glued down so you will have to use some force to pull it out.
    • Be careful not to pull it too hard it could bend the battery.
  7. Using the tweezers, slide them under the speaker and pull the speaker out. The back of the speaker is magnetic. Be careful to not touch it t other parts of the motherboard. The back of the speaker is magnetic. Be careful to not touch it t other parts of the motherboard.
    • Using the tweezers, slide them under the speaker and pull the speaker out.
    • The back of the speaker is magnetic. Be careful to not touch it t other parts of the motherboard.
  8. Using the tweezers, pull up on the clasp that is holding the motherboard down. Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera. Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
    • Using the tweezers, pull up on the clasp that is holding the motherboard down.
    • Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera.
    • Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
  9. Using the tweezers pull up on the three corners of the motherboard until it comes out. Using the tweezers pull up on the three corners of the motherboard until it comes out.
    • Using the tweezers pull up on the three corners of the motherboard until it comes out.
Kierra Schau
회원 가입일: 2017년 09월 28일
981 평판
안내서 5개 작성하였습니다
USF Tampa, Team S11-G2, Passmore Fall 2017 USF Tampa, Team S11-G2, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G2
3 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 1,148
