소개
This guide is for educational purposes and should not be used as a repair guide.
필요한 것
Place your thumb in the indent located at bottom left corner of the back cover.
The cover will pop up and begin to lift.
Continue to slide your fingers up the sides to remove the back cover.
Using tweezers, remove the gray plastic surrounding the camera lens.
FYI: Step 2 and 3 are not required to remove the back cover… Not sure why they are even here…
Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel.
After all the screws are removed from the back panel, lift the back panel off.
Just a little hint for anyone else pulling the back cover off: There’s a little rubber cover to the left of the camera lens that pops out. Remove that and pull up lightly on the connector you see underneath. This will disconnect the ribbon cable for the flash and light level sensor. Might save you a broken ribbon cable…
Using the tweezers pull up on the three corners of the motherboard until it comes out.
The author also forgot to mention the removal of two screws on the motherboard. Both are nestled very close to the battery, one between the sim card slots and the other between the top sim card and the sd card slot. The screws have been missing in pictures since step 4 and have not been mentioned. As best I can tell, they are T5 Torx.
