주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Motorola Moto X 2nd Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: 1 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: 1 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown, Motorola Moto X 2nd Generation Teardown: 1 단계, 이미지 3/3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Teardown: 2 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 2 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 2 단계, 이미지 3/3
    • Insert the eject pin into the hole inside of the port and push to open a gap between back cover and frame.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Teardown: 3 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 3 단계, 이미지 2/2
    • Slide the guitar pick to cut the adhesive sticker under the cover. It's a little strong. Finally, peel off the soft back cover.
  4. Motorola Moto X 2nd Generation Teardown: 4 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 4 단계, 이미지 2/2
    • Remove those two rubber cover.
  5. Motorola Moto X 2nd Generation Teardown: 5 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 5 단계, 이미지 2/2
    • Release the side button flex connector and battery connector respectively under the rubber cover.
  6. Motorola Moto X 2nd Generation Teardown: 6 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 6 단계, 이미지 2/2
    • Twist off all 18 screws on the middle housing and remove it easily.
  7. Motorola Moto X 2nd Generation Teardown: 7 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 7 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 7 단계, 이미지 3/3
    • Remove the logo.
  8. Motorola Moto X 2nd Generation Teardown: 8 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 8 단계, 이미지 2/2
    • Get the flex loosen from battery
  9. Motorola Moto X 2nd Generation Teardown: 9 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 9 단계, 이미지 2/2
    • Get the flex loosen from the battery.
  10. Motorola Moto X 2nd Generation Teardown: 10 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 10 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 10 단계, 이미지 3/3
    • Pull the battery sticker and pry up the battery.
  11. Motorola Moto X 2nd Generation Teardown: 11 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 11 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 11 단계, 이미지 3/3
    • Twist off the screw and pry up the securing bracket.
  12. Motorola Moto X 2nd Generation Teardown: 12 단계, 이미지 1/1
    • Remove the side buttons flex.
  13. Motorola Moto X 2nd Generation Teardown: 13 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 13 단계, 이미지 2/2
    • Release LCD connector.
  14. Motorola Moto X 2nd Generation Teardown: 14 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 14 단계, 이미지 2/2
    • Release digitizer connector.
  15. Motorola Moto X 2nd Generation Teardown: 15 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 15 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 15 단계, 이미지 3/3
    • Pry up the motherboard and remove it carefully. At that time, we can separate the LCD screen from motherboard and get it alone.
  16. Motorola Moto X 2nd Generation Teardown: 16 단계, 이미지 1/3 Motorola Moto X 2nd Generation Teardown: 16 단계, 이미지 2/3 Motorola Moto X 2nd Generation Teardown: 16 단계, 이미지 3/3
    • Release the connector and remove the rear camera.
  17. Motorola Moto X 2nd Generation Teardown: 17 단계, 이미지 1/2 Motorola Moto X 2nd Generation Teardown: 17 단계, 이미지 2/2
    • Remove front camera.
  18. Motorola Moto X 2nd Generation Teardown: 18 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 8개
Poking out the back cover through the SIM slot does NOT work on the leather backed version. I almost poked a hole through the leather but thankfully it held together. Maybe applying a heat gun to soften the glue would make this work.
tharty416 - 답글
When I reassembled my Moto X 2nd gen. after a battery change, I lost audio to the speaker. Audio jack works fine. Nothing is torn, but definitely something loose or not connected. I don't know where to look. Could you please help guide me to where it might be? Thanks!
phamtoan - 답글
I have a solution to the speaker not working after putting the phone back together.
The speaker wasn't connecting with the metal tabs on the phone back panel due to my replacement battery being a little thicker.
I was able to bend the speaker contact pins to connects with the relevant connectors and it started working. Slightly hacky but worked. I have posted pictures https://plus.google.com/+BenSycha/posts/...
Ben Sycha -
@wasrel Where did you purchase a replaccement battery and was it new?
Doug Hellinger -
Same problem. What is the answer?
alekskoptev - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 37,616
